February 10, 2026, 04:47:51 PM *
Author Topic: Quick exhaust Mod question...  (Read 961 times)
BlueLine984
Conyers, Georgia
« on: July 11, 2015, 06:48:39 AM »
Just a quick question to see what y'all have done or think. I'm debating just chopping the stock pipes right after the chrome guard before It goes into the rear muffler and putting all 3 pipes plus the first piggy into a 4" stack...
Has this been done by anyone?
Our greatest weakness lies in giving up. The most certain way to succeed is always to try just one more time. Thomas Edisonhttp://i47.tinypic.com/oh8fgz.gif
« Reply #1 on: July 11, 2015, 09:03:16 AM »
Probably but why?  If I were going to do something that radical I would try to find a set off a wreck that the front sections was still good on instead of chopping up a perfectly good set. You can't reverse your process or contact Mark T and have him make you a set that will sound the way they should modified.
« Reply #2 on: July 11, 2015, 01:09:04 PM »
I would do a lot of research using the search function on this site before I would chop OEM exhaust up. Undecided
As suggested look at MarkTs site over as part of your research:
http://www.horseapple.com/index.htm
« Last Edit: July 12, 2015, 04:26:09 AM by salty1 » Logged
My rides:
Steve K (IA)
Cedar Rapids, Iowa
« Reply #3 on: July 11, 2015, 03:32:34 PM »
As others have said, you might keep those stock pipes un-molested.
I would talk to Mark and check out your options before cutting into an intact exhaust.
 Wink
States I Have Ridden In
« Reply #4 on: July 11, 2015, 04:02:15 PM »
Your stock unmolested original OEM pipes are ONLY stock and unmolested and original ONLY ONCE.
Keep this in mind before you take a saw to your pipes.  They don't make them anymore.
RDKLL
VRCC #1231 VRCCDS #271
Mesa, AZ
« Reply #5 on: July 13, 2015, 05:15:33 AM »
Thats what I did to mine. I got these rejects from Mart T, I also have a set of his Mild2 Wild with crossover
Might be going back on after I paint them black
« Last Edit: July 13, 2015, 05:18:44 AM by RDKLL » Logged
