February 10, 2026, 06:45:02 PM *
Author Topic: Audiovox Cruise Control Servo location  (Read 929 times)
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« on: July 15, 2015, 10:29:47 AM »
After having the kit from Murphy for over a year, I have finally gotten down to desmogging the Valk, putting an a Dan-Marc, and installing the Cruise Control.
The only instructions I found, with lot's of pictures, shows the servo located where the tool kit would go, behind the battery. Trouble is, I have a relay board I made, with 4 or 5 relays, to run the tail/brake/running lights, and can't find anywhere else to put that board.
My question is, has anyone found an alternate location for the servo, suitable for a standard or tourer, than in the battery box? I saw one photo from Kingbee, but looks like it's under the fairing on an Interstate.
Thanks, in advance!
R
« Last Edit: July 15, 2015, 10:37:59 AM by Walküre » Logged
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
« Reply #1 on: July 15, 2015, 10:42:34 AM »
MC Cruise puts their vacuum servo in front of the battery, behind the centre cover.
« Reply #2 on: July 15, 2015, 11:00:02 AM »
Mine is down where the pair valve used to be. After your desmog there should be plenty of room.
Walküre
Oxford, Indiana
« Reply #3 on: July 15, 2015, 11:05:53 AM »
Thanks, gents - finally found a picture of where the McCruise is located. And I had thought about where the PAIR valve was removed, but since I don't have the Dan-Marc fuel shutoff installed, wasn't sure about fitment there.
Which brings another question - Meathead, are you using a vacuum cylinder, and if so, it is positioned down in the valley, also?
Thanks, again!
R
« Last Edit: July 15, 2015, 11:11:39 AM by Walküre » Logged
Roger Phillips
Oxford, IN
VRCC #31978
« Reply #4 on: July 15, 2015, 11:16:15 AM »
No vacuum cylinder on mine. It has a line to each #3&4 . Works great  cooldude
« Reply #5 on: July 15, 2015, 11:20:24 AM »
If you want I can send you a pic of the setup when I get home. You would need to PM me a # to text to though. I'm still not smart enough to put pics on here  Undecided
Chippy01
Gorey, Ireland
« Reply #6 on: July 15, 2015, 11:32:31 AM »
I had the same problem, no room to put the actuator under the seat, so I mounted it here :-
Then I fashioned a cover out of plastic gutter downpipe, with a cap at the upper end:-
It's a tight fit, but has worked flawlessly for over 8 years in all weathers.
For the vacuum chamber, I fashioned this out of 1-1/4" plastic waste pipe:-
and fixed underneath the swingarm.
'98 GL1500C Standard Valkyrie
'88 VF750C SuperMagna
'89 GL1500 GoldWing
