February 10, 2026, 04:47:26 PM *
Author Topic: IS vs Standard or Tourer ICM/CDI's  (Read 1404 times)
Earl in Pensacola
« on: July 16, 2015, 05:15:01 PM »
My '97 Tourer is up to 294K  and gettin' kind'a noisy, so I'm considering an engine swap.  The replacement engine is a 2000 IS with only 17,760K.  I'm sure I remember reading, here on the board quite some time ago, that the ICM/CDI for an IS will actually "improve" the preformance in a Standard or Tourer due to slightly different mapping.
My question is will the ICM/CDI out of a Standard work with an IS engine?? I realize that there could be a little less "grunt" at the lower rpm range on the newly installed IS engine.
Has anyone had any personal experience with this??
Earl in Pensacola
justmeedp@cox.net
« Reply #1 on: July 16, 2015, 05:19:02 PM »
yes all will interchange
see ICM curves here
http://www.timskelton.com/valkyrie/tech/trigger_wheel_plus_dyna3000.htm
Earl in Pensacola
« Reply #2 on: July 16, 2015, 05:39:12 PM »
Thanx for the quick reply.  Just want to say that I'm not really looking for more power, I just don't want to have to buy the much more expensive IS CDI, if the one on my Tourer is a "plug & play"  with the IS engine and will function properly with that engine.
Thanx,
« Reply #3 on: July 16, 2015, 07:14:38 PM »
saw this recently $100
http://www.ebay.com/itm/HONDA-VALKYRIE-INTERSTATE-GL1500-CDI-ECU-ECM-ENGINE-CONTROL-UNIT-MODULE-1931-/151664029610
