April 29, 2026, 10:38:58 AM
Texas Chapter
(Moderator:
Daniel Meyer
Clutch fluid
Topic: Clutch fluid (Read 1495 times)
Mofla
San Antonio TX
Clutch fluid
July 17, 2015, 06:25:46 AM »
I seemed to be losing fluid level. All I've done is bleed and added fluid. Thoughts & thanks ! Mofla
Rocketman
Seabrook, Texas
Re: Clutch fluid
July 17, 2015, 09:54:24 AM »
Is it operating nominally? If you didn't get it tightened up all the way to the point that it's leaking, it probably wouldn't disengage fully.
Old Geezer Richard
San Antonio , Tx
Re: Clutch fluid
July 18, 2015, 01:42:39 PM »
Hey MoFo , bleed it again brother just to be sure
... Thanks your pal the Geezer
If you don't care where you're going, then you ain't lost , Murphy's Law because wherever you are going to , it ain't going nowhere .... San Antonio,Tx.
Mofla
San Antonio TX
Re: Clutch fluid
July 20, 2015, 06:56:13 AM »
Thanks ! Will check it out !
big poppa pump
San Antonio, TX
Re: Clutch fluid
July 20, 2015, 07:02:38 AM »
If you are losing fluid and not seeing any drips on the floor, then check your slave cylinder. Chances are that your oil seal might be shot and seeping into the crankcase.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
Mofla
San Antonio TX
Re: Clutch fluid
July 24, 2015, 04:46:34 PM »
Hey big poppa, that's making sense. I did re bleed an wound up with same problem. I don't see any fluid drips or spots. I'm not sure where the slave cylinder is but I will research. I may holler back , much appreciation for the response,,, luv that bobber !! Mofla
Mofla
San Antonio TX
Re: Clutch fluid
Reply #6 on:
July 24, 2015, 05:47:56 PM »
Now I know the slave cylinder ! For the time being bled one more time , feels good for now , we will see !! Thanks again peeps ! Mofla
