September 02, 2025, 06:09:50 PM
No play in the clutch
Topic: No play in the clutch (Read 639 times)
wellandfit
Fredericksburg TX
July 17, 2015, 11:17:42 AM »
Hey Guys, I need help with adjusting the clutch handle. There's no play at all. What do you think?
Re: No play in the clutch
July 17, 2015, 01:27:06 PM »
Its not adjustable and there is almost no freeplay. The only way to add some is to remove the pushrod and shorten it a bit. [ I like freeplay]. But, most folks don't do that and just use it as is.
Well, I guess have to now ask how the clutch operates ? It is still nice and smooth or is it rough and jerky ?
If its nice and smooth then I'd think its OK.
Last Edit: July 19, 2015, 11:41:30 AM by Patrick
July 17, 2015, 03:43:33 PM »
Rebleed the hydraulics and if that doesn't work, I'd say your rivets have gone bad in the clutch. New clutch plates is probably what you need.
July 18, 2015, 07:31:13 AM »
Quote from: wellandfit on July 17, 2015, 11:17:42 AM
You're fine, nothing needed, as long as the shifting is good.
As far as the scare comments, just disregard it!
=> InZane XXV
