December 19, 2025, 10:55:56 AM *
Author Topic: My IS won't start  (Read 1681 times)
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« on: July 24, 2015, 10:49:36 PM »
FIXED
Guys I need some technical advice.  I wasn't able to ride for a few weeks, I went to start my IS and nothing, the headlights went out and the pod lights shone brightly with no dimming, but no rumbling of awesome power.  I assumed the battery was weak even thought the pods didn't dim so I plugged in the battery tender and jumped on the standard instead.  I let 'er charge for 24 hours and tried to start 'er again with the same result.
I checked the battery before hitting the start switch and she had about 13.7 volts, with key on and the start switch depressed she dropped to 11.6 volts.  I know normally a weak battery will end up spinning the starter but not starting the motor.  I got no clicks, no whirrs, nothing!
Since electrical issues are my nemesis I'm asking for suggestions, what should I check next?
TYIA!
« Last Edit: July 25, 2015, 11:43:54 AM by Houdini » Logged
Mofla
San Antonio TX
« Reply #1 on: July 25, 2015, 06:52:50 AM »
Starter switch ?
desertrefugee
Chandler, AZ, USA
« Reply #2 on: July 25, 2015, 07:05:42 AM »
Battery connections, ground connections.
'97 Bumble Bee,  '78 GL1000, '79 CBX, '78 CB750F, '74 CB750
Valker
Wahoo!!!!
Texas Panhandle
« Reply #3 on: July 25, 2015, 07:52:16 AM »
Kill switch? Roll Eyes
« Reply #4 on: July 25, 2015, 08:30:59 AM »
Kick stand down and tranny in a gear?
Houdini
Allen, TX
« Reply #5 on: July 25, 2015, 09:03:02 AM »
I went to check the kill switch, kickstand, neutral, etc, verified all were correct and hit the starter switch again.  There was a loud click from under the right cover and now nothing, no headlights, no warning lights, nothing.  I assume I blew a fuse.....   Sad
Houdini
Allen, TX
« Reply #6 on: July 25, 2015, 11:46:23 AM »
Turns out I had a loose connection,  Roll Eyes a little cleaning and tightening and all is well.
Thanks for the suggestions.
RainMaker
Arlington, TX
« Reply #7 on: July 25, 2015, 11:55:44 AM »
That's what I suspected.
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
john
tyler texas
« Reply #8 on: July 27, 2015, 03:42:58 PM »
                             bad ground connections ?         ???
vrcc # 19002
Houdini
Allen, TX
« Reply #9 on: July 29, 2015, 04:55:59 PM »
Yes, the one on the battery, it felt tight at first wiggle but when I went back to check again the bolt spun loose by hand.
« Reply #10 on: July 31, 2015, 01:43:10 PM »
I have had this happen on my Valk and my 07 Wing.  A loud POP, then nothing......  pulled the cables off, wire brushed them clean, a little dielectric (sp?) grease, put them back on snug and it fires right up...
Glad it wasn't more serious.
Hay  Cool
nogrey
Nampa, Idaho
« Reply #11 on: July 31, 2015, 01:58:58 PM »
Reminds me of one of the valkyries I bought for a friend. He and I travelled 400 miles to get it. I had spoken to the seller on numerous occasions about the condition of the bike. It was very much as represented when we got there, but wouldn't start. I could tell he was as frustrated as me. Ultimately we jump started it and it ran like a freaking racehorse! But I got him to come down a couple of hundred bucks because I didn't know what I was looking at in repairs. I was thinking alternator or battery or both. Trailered the bike home. When I went to work on it I had bought a new battery to give that a try. I didn't even get the old one out. Went to take off the ground wire and it was loose as a goose. I tightened it up and it started right up. That was 2 years ago and my friend is still riding on the same battery.
