February 10, 2026, 06:46:30 PM
Do I really need to...
Topic: Do I really need to... (Read 1030 times)
biguglyman
Brockport, NY
July 27, 2015, 12:37:10 PM »
...buy a whole new can of brake fluid? Bought a big one a few months ago to bleed the clutch. Still got plenty left and want to bleed the brakes. I know...it's only $xx, but I hate to waste all I got left...
Re: Do I really need to...
July 27, 2015, 12:53:38 PM »
Brake fluid is hydroscopic. It absorbs moisture from the atmosphere.
Do you really want to take the chance?
Buy another bottle....it's not that expensive.
July 27, 2015, 02:41:36 PM »
Naw, If you has the cap on tight, you're good to go. It takes a long time for it to absorb water and it will change color to brown as it goes. If it's nice and sparkly looking clear and clean, it will be fine to use. Don't take all those scare comments to heart, always remember they have no problem spending your money.
July 28, 2015, 06:25:52 AM »
I wouldn't get too excited about a few months sealed on a shelf. If it was a concern, then we should be changing our brake/clutch fluids every few months as well.
And the word for something that absorbs moisture from the air is
hygroscopic
, not
hydroscopic
. A hydroscope is a device for viewing underwater objects.
BobB
July 28, 2015, 08:31:44 AM »
Everything mentioned above is good advice. I'll just add that it may be better to buy DOT4 fluid in smaller containers, especially if your concerned about shelf life once opened. That's what I do...
July 28, 2015, 09:07:48 AM »
Quote from: BobB on July 28, 2015, 08:31:44 AM
Yeah, one small container does both brakes and clutch with a little left over.
biguglyman
Brockport, NY
Reply #6 on:
July 28, 2015, 01:20:50 PM »
Stuff I bought says DOT 3 and 4.
RonW
Newport Beach
Reply #7 on:
July 28, 2015, 02:11:06 PM »
biguglyman, what's the time stamp on the bottle that you bought? When the brake fluid was bottled at the factory? An unopened plastic container doesn't provide a 100 percent hermetical seal. The contents absorbs moisture through the plastic.
Yes, *hygroscopic*.
2000 Valkyrie Tourer
