August 11, 2025, 06:51:41 PM *
Author Topic: Whirring chatter noise coming from rear.....  (Read 1711 times)
954rocks
« on: August 01, 2015, 10:27:16 AM »
I'm hearing a whirring chatter noise coming from the rear of my 2002 Valkyrie standard when I apply the rear brake. I removed the rear brake caliber for inspection and the pads are fine with plenty of material left. It only makes this noise when the rear brake is applied. Anyone experience a similiar problem..?
954rocks
« Reply #1 on: August 01, 2015, 10:28:24 AM »
I forgot to mention that the bike has a little over 21K miles.
« Reply #2 on: August 01, 2015, 11:10:36 AM »
Left rear wheel bearing.
Tfrank59
'98 Tourer
Western Washington
« Reply #3 on: August 01, 2015, 11:37:48 AM »
Wheel bearing after only 21,000?   I suppose it could happen but not too likely.  I hear whirring noise when my rear brake is applied – it's the sound of the pads on the rotor (my brake pads are good too).
-Tom
« Reply #4 on: August 01, 2015, 12:08:53 PM »
OEM pads?
trout dude
Hammond Louisiana
« Reply #5 on: August 01, 2015, 12:20:47 PM »
I would check what BF & Bighead said and also something MITCHO taught me make sure the slider pins  are lubed and also that your rear brake pedal is not hanging up.
  Trout Dude
954rocks
« Reply #6 on: August 01, 2015, 01:59:38 PM »
Trout Dude, when I had the rear caliber off I lubed the slider pins.
I believe they are OEM pads because I had planed to change them out and ordered a set of Honda brand. The current pads look identicle to the OEM pads from what I could tell. Interesting that Tfrank59 hears same sound on his bike; does anyone else notice this noise when applying their rear brakes..? I guess it could be a wheel bearing but I'm only hearing it when applying the brake.
« Reply #7 on: August 01, 2015, 02:19:33 PM »
I think all you are hearing is the pads rubbing the rotors.
954rocks
« Reply #8 on: August 01, 2015, 02:38:21 PM »
This may be true...  I've owned several bikes with rear disk brakes, just never heard this sound so pronounced.
« Reply #9 on: August 01, 2015, 07:31:05 PM »
I'm too lazy to do a search, but during my many years of reading this board, I know that weird noises when the rear brake is applied HAS been found to be caused by a bad wheel bearing.
Firefighter
Harlingen, Texas
« Reply #10 on: August 02, 2015, 10:12:22 AM »
The rear brake caliper has a pad spring that applies tension to the pads. Might make sure its still good and in place correctly. Also there are two rubber boots that if missing or wore through might cause a chatter. If this is a new noise might just change pads and see. Make sure everything back there is still tight and not falling off. Don't know, .0136 cents worth. Let us know  Firefighter
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
954rocks
« Reply #11 on: August 02, 2015, 10:15:55 AM »
Thanks firefighter, I will search for a rear caliber diagram and check this out !!
t-man403
Valk-a-maniac
Calgary, Alberta, Canada.
« Reply #12 on: August 23, 2020, 01:43:44 PM »
5 years old!
Wonder if the problem was resolved?
Nothing worse than to be left hanging......
