November 26, 2025, 09:54:41 AM
Starter button maintenance – couldn't do it
Topic: Starter button maintenance – couldn't do it (Read 1379 times)
Tfrank59
'98 Tourer
Western Washington
August 01, 2015, 06:12:50 PM »
My starter button has been acting up on me, so I figured I better do the maintenance on it.
http://www.rattlebars.com/mtz/starter.html.
My first time trying it. I couldn't get the black plate with the wires pryed loose from the body of the switch – that sucker's really stuck in there. I even ground a little hook tool to pry with which fit perfectly in there but it still wouldn't budge. I was afraid I was going to break something. Any ideas what I'm doing wrong?
-Tom
Keep the rubber side down. USMC '78-'84
Re: Starter button maintenance – couldn't do it
August 01, 2015, 06:36:47 PM »
Quote from: Tfrank59 on August 01, 2015, 06:12:50 PM
If you look closely you will see four tabs, use a small knife and gently pry the tab away from the peg that fits in the hole
Tfrank59
'98 Tourer
Western Washington
August 01, 2015, 07:10:27 PM »
Thanks, I'll give it a try.
-Tom
=> InZane XXV
