November 26, 2025, 10:22:12 AM *
Author Topic: Risers for bars  (Read 1468 times)
skinner
« on: August 04, 2015, 06:11:59 PM »
Would some please give me the web sight for a paire of risers they raise the bars up two in and back there jest blocks and come with the longer studs solid billet aluminum I think     Thanks a head of time for info
davit
Deerfield, WI
« Reply #1 on: August 08, 2015, 04:54:46 AM »
These?
http://www.twistedthrottle.com/handlebar-risers-honda-shadow-valkyrie-magna-vtx1300-pacific-coast-pc800-with-1-inch-diameter-handlebars
skinner
« Reply #2 on: August 08, 2015, 06:10:42 PM »
Yep that's them thanks I looked everywhere and couldn't find them I'm a happy camper
davit
Deerfield, WI
« Reply #3 on: August 08, 2015, 06:29:21 PM »
Before you order call and have them check the bolt threads.  What came with mine were sae not metric:  5/16-20 instead of m8-1.25.  The threads are virtually interchangable but won't go without recutting.
slider
mulberry arkansas
« Reply #4 on: August 09, 2015, 02:00:37 PM »
I recently had a pretty serious accident (was forced off a bridge) I thought my bars were bent  on closer inspection it appears the riser on the left side is bent..replacee or can it be adjusted??Thanks
a proud navy veteran
« Reply #5 on: August 09, 2015, 05:30:19 PM »
You may want to use some good judgement with those.  They look like what one of our members had that broke in half on him while going down the road.
They may work for you.
davit
Deerfield, WI
« Reply #6 on: August 10, 2015, 10:04:53 AM »
They are under compression the only parts that could break are the bolts.
« Last Edit: August 10, 2015, 05:21:50 PM by davit » Logged
skinner
« Reply #7 on: August 10, 2015, 10:35:36 AM »
Are there any better risers out there that any one knows of that possibly wouldent brake and have the wright bolts
« Reply #8 on: August 10, 2015, 10:56:32 AM »
Here's the story about Daniel Meyer's risers breaking... his were different than
the ones talked about on this thread...
http://lifeisaroad.com/blog/2009/05/19/annnd-nobody-died/
davit
Deerfield, WI
« Reply #9 on: August 10, 2015, 05:27:15 PM »
Here's how they look installed.  Note the risers are factory original, this product is simply a spacer:
davit
Deerfield, WI
« Reply #10 on: August 10, 2015, 05:35:36 PM »
Skinner, this is probably the cheapest, easiest solution available for our bikes.  The installation is seamless and requires no rerouting of cables or hoses.
As for the bolts, if I were to do it all over again I would call Twisted Throttle, explain my recent experience (two weeks ago) and ask them to open the package and spin an m8-1.25 nut on the bolts to verify accuracy.  It's possible I had one-off bad luck and the rest were packaged correctly.
Bone
« Reply #11 on: August 11, 2015, 03:48:03 AM »
Bought these in 2011 from Ebay still on the bike. Just looked thru the listings and didn't find similar risers.
