February 10, 2026, 08:18:42 PM *
Author Topic: CB Hardware  (Read 782 times)
Paladin528
« on: August 10, 2015, 11:38:48 AM »
I am looking fro the mounting hardware or at least all of the dimensions for the mounting hardware for the honda CB.  I am working on a project and the mounting hardware would work perfect to mount the electronics.
Brad
« Reply #1 on: August 10, 2015, 08:05:39 PM »
How about DL the document.
http://valkyrienorway.com/download.html
Between that, ebay pictures, and you with a tape measure to size up your rails under the trunk, you should be good to go.
« Last Edit: August 10, 2015, 08:44:56 PM by gordonv » Logged
Paladin528
« Reply #2 on: August 11, 2015, 05:14:16 AM »
yeah I was trying for the easy way out...LOL
Dusty
Mill Bay B.C.
« Reply #3 on: August 13, 2015, 06:46:45 PM »
 Brad
You owe me one   Grin Grin
Main bar  Two of   1/8” thick        11/16” wide        10  3/8” overall length      9  5/8”  center to center hole distance   Flat bar is bent 3/8” offset on each end   .
Flat bar Two of    3/32” thick       9/16” wide      5  5/8” long      2 slotted holes .226” wide by .330” long          5” center to center for holes
Crossover strap   two of   3/32” thick       9/16” wide      5  5/8” long          2 slotted holes .226” wide by .330” long          5” center to center for holes        Shape of strap 5/8” then bend 90 degrees then 1  5/16” long and bend 90 degrees then 4 3/8” then bend 90 degrees then 1  5/16” then bend 90 degrees then 5/8” and cut off.
Dusty
« Last Edit: August 13, 2015, 08:47:22 PM by Dusty » Logged
Paladin528
« Reply #4 on: August 14, 2015, 05:37:20 AM »
Thanks dusty.  I do owe you one.  Saves me removing my trunk,to take the initial measurements.
No sure where I would have got the details for the bends.
