February 10, 2026, 08:17:50 PM *
Author Topic: Adding risers  (Read 987 times)
Dude
« on: August 12, 2015, 12:08:57 PM »
I need to add risers to my 98 Valkyrie and I do not want to change cables. Does anyone know the maximum height riser I can use before I need to install longer cables?
« Reply #1 on: August 12, 2015, 01:16:51 PM »
The OE riser is 3 1/8" tall.  You can go to a 4" or perhaps a little more without changing anything.  Because they sit on an angle on the triple tree (and are mostly curved, except for riser spacers), measurements are a bit tricky.
These are a bit steep, but they are 4" (or so), and give about as much rise and pullback as you can get without changing anything.  (except you might need to turn the wire clips on the back of the handlebars around 180*, and that is easy peasy)
http://www.aeromachmfg.com/RISER_SET_4_VTX_Retro_1300_p/am-4120c.htm
These are cheaper ones, that one of our members had crack clear through on one side at the bolt holding the bar.  http://www.jpcycles.com/product/ZZ37171
These are riser spacers (you just add to your existing risers), and cheaper yet.  And if they add an inch to 3 1/8" stock risers, then total height should be 4 1/8" (but they may not give quite as much pullback as a complete riser set, but I don't know).
http://www.twistedthrottle.com/handlebar-risers-honda-shadow-valkyrie-magna-vtx1300-pacific-coast-pc800-with-1-inch-diameter-handlebars
You can also look at a site called Scootworks.
http://www.scootworks.com/shop.cgi/page=partshonhandle.htm/SID=PUT_SID_HERE
« Reply #2 on: August 12, 2015, 01:21:09 PM »
A four inch riser for sure. Maybe five inch if your willing to reroute your throttle cables.
My rides:
