February 10, 2026, 08:18:35 PM *
Author Topic: Cobra Exhaust Install  (Read 1220 times)
Ard103
Mims, Fl
« on: August 15, 2015, 03:00:01 PM »
The Valk had an old rusty black 6 into 6 exhaust on it so I bought a new chrome set.
I am having one heck of a time starting the acorn nuts onto the stubs at the heads.
I can get maybe one thread of each nut started, and only one side of the number 5 pipe.
I used new gaskets, are there different thicknesses of header gaskets out there?
The ones i have are part number 16-5976, and are 3/16 thick.
Thanks in advance
N8171S
Marlboro, Mass
« Reply #1 on: August 15, 2015, 03:09:26 PM »
Did you pry out the old copper gaskets?  If not that could be the problem.
Ard103
Mims, Fl
« Reply #2 on: August 15, 2015, 03:13:14 PM »
Yes, destroyed them getting them out. Maybe shoulda left them in...
« Reply #3 on: August 15, 2015, 03:15:43 PM »
I was going to say that they aren't "gaskets", but more like crush washers. One in each hole.
Which new set of exhaust did you buy, who says it fits?
Ard103
Mims, Fl
« Reply #4 on: August 15, 2015, 03:29:16 PM »
Got the Cobra's and crush washers from Amazon, the pipes are the 1269's, I verified the part number at the Cobra website. The old crush washers are just 1/16 thinner than the new ones, crushed a little evidently. The flanges on the new set is a little different from the old set, thicker evidently.
Ard103
Mims, Fl
« Reply #5 on: August 15, 2015, 03:44:21 PM »
I was just reading the "Help broke a bolt" thread, I wonder if I could back the studs out of the heads about 1/4 of an inch, that would plenty of thread in the head I would think.
BonS
Blue Springs, MO
« Reply #6 on: August 15, 2015, 10:36:16 PM »
I recently installed a set of 6-into-6's and used new exhaust gaskets. I dug out out old gaskets and found that the studs were just barely long enough to catch a thread on the first install. I carefully, and evenly tightened them down and the new gaskets crushed down as I went. Be sure to check them after a few heating/cooling cycles to make sure they're still tight.
« Reply #7 on: August 16, 2015, 04:43:07 AM »
I've never installed Cobras...
If you're using these fiber gaskets:
... it might be worth trying some OEM gaskets...
They're, like, hollow copper rings that crush down into nothing...
Ard103
Mims, Fl
« Reply #8 on: August 16, 2015, 04:51:02 AM »
Those are the ones I am using. And it looks like the old ones that came off with the old exhaust. Are those fiber gaskets just a cheap aftermarket, or are they for a different application?
I will get the OEM ones Monday, Thanks
Ard103
Mims, Fl
« Reply #9 on: August 16, 2015, 04:53:29 AM »
Thanks for the info. I was a little afraid of stripping the stud with only one thread. In the post after yours, are those the gaskets that you used or did you use the OEM ones?
« Reply #10 on: August 16, 2015, 05:17:51 AM »
You can get the fiber ones several different places. Some people really
like them, so I don't want to say they are no good, but they are
WAY thicker than OEMs, so the change might help you.
Ard103
Mims, Fl
« Reply #11 on: August 21, 2015, 01:01:09 PM »
The OEM ones came in the other day, put those in and I am able to start all of the acorn nuts and start crushing the gaskets.
The thicker ones I had bought of off Amazon, the dealer is going to issue a refund for them, Powersports I think it was. $20 bucks is $20 bucks.
Thanks for the help everyone.
BonS
Blue Springs, MO
« Reply #12 on: August 21, 2015, 01:43:17 PM »
I used the hollow copper gaskets and they crush easily to quickly pick additional threads, but I was certainly concerned and went slowly.
