February 10, 2026, 10:27:25 PM *
Author Topic: Need side stand spring bolt length size  (Read 939 times)
lljjmm
« on: August 24, 2015, 11:20:12 AM »
Bolt broke on side stand that holds the spring. Going to replace it with a common bolt. Don't have both pieces to measure. What would be its length?
« Reply #1 on: August 24, 2015, 12:26:14 PM »
A standard bolt regardless of hardness will not stand up to the use. You gain nothing.
« Reply #2 on: August 24, 2015, 12:52:09 PM »
I don't follow you.  Are you saying the original part is made of some special titanium-like substance that can't be duplicated by even a (metric) class 10.9 or 12.9 bolt?  People have replaced that special part with an appropriate assembly of bolt and nuts.
Jack B
Two Rivers Wis
« Reply #3 on: August 24, 2015, 01:03:26 PM »
I have a brand new bolt and spring still in the plastic bag, if you want it let me know. $10
Lbrey@charter.net
Let’s RIDE
lljjmm
« Reply #4 on: August 24, 2015, 07:24:52 PM »
So what is the length?
« Reply #5 on: August 25, 2015, 06:56:03 AM »
If you look at the OEM part and compare it to a regular bolt, it's very easy to see the cross sectional difference is considerable and probable in the area of two or more times greater. Which will translate into greater strength and able to withstand the rigors of constant use and strain.
IamGCW
727 hood
« Reply #6 on: August 28, 2015, 05:18:18 AM »
6 x 1.0 x 50 is what I used on a trip.  Honda has them for a snow blower.  Works but not exactly right.  Had to remove the kickstand safety.  I think I needed 2 or 3 nuts as well.
Gil
Gil
lljjmm
« Reply #7 on: August 28, 2015, 07:17:04 AM »
Thanks Gil, much appreciated
