February 10, 2026, 10:27:26 PM *
Author Topic: Rear shocks  (Read 1161 times)
auditray2007
Athens Greece
« on: August 24, 2015, 01:27:42 PM »
Hi Guys,
Does anybody know if it is possible to fit new springs into the rear shocks on my tourer. They are oem chrome barrel type on there. I remember reading on here that someone did it but was it on the barrel type or spring type shocks.
« Reply #1 on: August 24, 2015, 01:52:28 PM »
look for a pair of I/S shocks first IMO
rebuilds
http://www.valkyrieforum.com/bbs/index.php/topic,45903.0.html
http://www.valkyrieforum.com/bbs/index.php/topic,73751.0.html
http://www.valkyrieforum.com/bbs/index.php/topic,13356.0.html  GW shocks fit
auditray2007
Athens Greece
« Reply #2 on: August 24, 2015, 03:23:58 PM »
Thanks for that. Cant find those springs 8 Track suggests. I will wait to see if the dampers are ok when I take them apart before deciding what way to go. Wallet suggests spring replacement if dampers are ok. But if the springs are that expensive what about the 412's. I am running a car tyre on there. Does not rub with 2 up so what should I watch for other than the 13" issue which I want to stay at. I am 6' & 220lbs. 2 up sometimes.
What are the differences between the 412's / 430 / 440's and are they worth the extra cost
auditray2007
Athens Greece
« Reply #3 on: August 25, 2015, 01:39:52 PM »
Does anybody know if the car tire fitted would determine the type of shocks. Obviously it is heavier than the standard issue.
« Reply #4 on: August 26, 2015, 08:08:19 AM »
No.  The tire is not supported by shocks.
« Reply #5 on: August 26, 2015, 09:59:08 AM »
the tires are close in weight. go to tire sites, most of the weights are usually posted.
search my post about I/S suspension differences and how the fork and shocks are different.
Willow, if a tire is much more heavier than a standard tire it could need a different shock with a different rate of rebound and dampening to control the upward and downward movement.
 But yes u are correct the spring rate would not have to be different.
8Track
Adelaide, South Australia
« Reply #6 on: August 27, 2015, 03:23:44 PM »
Here they are mate. A simple search on Ebay of "DNM spring" brought them up!
http://www.ebay.com.au/itm/DNM-REAR-SHOCK-SPRING-300LBS-20CM-LENGTH-DIRT-BIKE-/170957283695?hash=item27cdd9216f
Cheers,
8Track
auditray2007
Athens Greece
« Reply #7 on: August 28, 2015, 06:22:51 AM »
Thanks for that 8TRACK. I entered "mini-parts-porter" and came up with nothing. Old timers eh. Whats your opinion on the car tire and those springs fitted.
8Track
« Reply #8 on: August 28, 2015, 04:02:11 PM »
The springs are great. I can't comment on the car tyre though - never used one.
