Valkpilot
What does the data say?
Corinth, Texas
« on: August 25, 2015, 09:00:03 PM » |
« Last Edit: December 28, 2023, 06:21:41 PM by Valkpilot »
LL
« Reply #1 on: August 26, 2015, 04:50:31 AM » |
Not a bad job
 VRCC #472
Friendsville, TN, Troy, MI
« Reply #2 on: August 26, 2015, 04:53:57 AM » |
Where'd You Get The Abs Sheets?
 Friendsville, TN - Troy, MI
Jack B
« Reply #3 on: August 26, 2015, 05:00:23 AM » |
I'm impressed itlooks great what brand of paint did you use.
Let’s RIDE
« Reply #4 on: August 26, 2015, 05:05:59 AM » |
Wow! Great job. Looks awesome. Tell us about your buffing skills how u did it, please.
NCGhostrider
Jacksboro, TX
« Reply #5 on: August 26, 2015, 05:34:12 AM » |
How strong are the joints? It looks great! Lol I know where this will end up.
Craig NcGhostrider 99 I/S
#6674 99 I/S Why aren't we riding? Anyone? Anyone?
« Reply #6 on: August 26, 2015, 06:51:25 AM » |
Very nice work.  Back from the dead. When mine was exploded, I couldn't even find all the peices or honda rack (freeway).
Red Diamond
« Reply #7 on: August 26, 2015, 07:41:35 AM » |
Great job Dave, doesn't look like it was put together with so many pieces.
Valkpilot
Corinth, Texas
« Reply #8 on: August 26, 2015, 07:55:36 AM » |
I got the ABS sheets from Amazon: http://www.amazon.com/gp/product/B00DCKGXKG?psc=1&redirect=true&ref_=oh_aui_search_detailpage Note that I only had to use small pieces for reinforcement and to fill in one triangular area. I really bought it for a much bigger saddlebag and lid repair job that's hanging out in the garage. I used DupliColor Universal Black and DupliColor Clear. The ABS cement chemically welds -- it's not an adhesive. So the seams are as strong as the original material, provided the cracks are fully filled. I threw lots of ABS cement in the cracks, then used an orbital sander with 120 grit to knock everything down. Low spots were refilled with ABS cement, pits filled with auto body glazing putty. I used a heavy-layer primer then wet sanded with 800 grit, more primer, then wet sanded with 1500 grit. The trick is to fog on the color in very light coats (50% coverage), shaking the can after every complete pass. Repeat, repeat, repeat until you can see the overspray "melt" into the paint on the surface. You want to get right to the point of sag, then stop a minute, then repeat. At this point, provided the temp, humidity, and wind are right, you've got a pretty good looking paint job. Now let it dry for 24 to 48 hours. I let this dry for a week or more between work sessions, because I was in when-I-have-a-minute mode on this project. I then color sanded (wet) with 2000 grit to even out any orange peel. Then I fogged on a couple more black coats and immediately began fogging on the clear. Again, the trick is to take it to the point of sag where the overspray is melting in. With clear, it will start to look milky in spots when you get it heavy enough. After a week of drying, I lightly sanded with 2000 grit. I had to address a couple of sags in the clear, but they were no problem. Finally, I used a 3M scratch repair kit that comes with a 3" sanding disk and two different pads. Using a corded electric drill (cordless won't spin fast enough to be really effective) I started with 3M rubbing compound on the rougher pad and buffed the whole surface. I kept a spray bottle handy and occasionally misted the surface. You can burn the paint if you get too dry or stay in one spot too long. Then I switched to the softer pad and McGuirer's Swirl Remover, again misting the surface to keep from being too dry. I finished it off with two coats of Liquid Glass polish.
« Last Edit: August 26, 2015, 09:40:40 AM by Valkpilot »
RainMaker
Arlington, TX
« Reply #9 on: August 26, 2015, 07:58:14 AM » |
Looks better than mine that has never been broken.
 2005 BMW R1200 GS 2000 Valkyrie Interstate 1998 Valkyrie Tourer 1981 GL1100I GoldWing 1972 CB500K1
Disco
Republic of Texas
« Reply #10 on: August 26, 2015, 09:36:17 AM » |
Looks great, Dave!
2000 Bumblebee Tourer, 98 Yellow & Cream Tourer, 97 Rescue blower bike 22 CRF450RL, 19 BMW R1250RT 78 CB550K, 07 Helix 71 MT50 Trailhopper .jpg) VRCC 27,916 IBA 44,783
john
« Reply #11 on: August 26, 2015, 10:09:05 AM » |
« Last Edit: August 26, 2015, 10:10:56 AM by john »
vrcc # 19002
f-Stop
'98 Standard named Hildr
Driftwood, Texas
« Reply #12 on: August 26, 2015, 05:15:28 PM » |
Wow! Great job…I could only hope to have the vision and then the patience you showed to complete such a daunting task.
« Reply #13 on: August 26, 2015, 06:42:22 PM » |
OUT.......STANDING! Hay  Jimmyt
Timbo
« Reply #14 on: August 27, 2015, 04:10:55 AM » |
Fantastic job, Dave. Thank you for the well documented process as well....as someone said, you have a great deal of patience and skill.
BnB Tom
Where'd old times go?
Frisco, TX
« Reply #15 on: August 27, 2015, 04:39:16 AM » |
Yes indeedy! Great looking Had I known you enjoyed the 'paint and body' business so much, I might have have requested a quote on touching up MY saddlebag.  You might recall the ugly scuff I received on my saddlebag which occured about a year ago.  Seems as tho an electric gate closed faster that I anticipated.
RDAbull
« Reply #17 on: August 27, 2015, 08:46:04 AM » |
Great job. I showed it to a friend in the office this morning and he asked if he could send you the 56 pieces from his Vette's end for the same kind of work?
2015 GoldWing Trike 1999 Valkyrie Interstate Trike, gone but not forgotten
Valkpilot
Corinth, Texas
« Reply #18 on: August 27, 2015, 11:10:32 AM » |
Large stacks of cash make many things possible!
Valkpilot
Corinth, Texas
« Reply #19 on: August 27, 2015, 11:15:55 AM » |
Thanks to all for the compliments. I've always enjoyed body work, but this is one of my more successful efforts.
Mostly what it takes is time.
There's a reason good paint jobs cost a lot.
BnB Tom
Frisco, TX
« Reply #20 on: August 28, 2015, 04:54:33 AM » |
Large stacks of cash make many things possible!  WOW! That's the same thing "The Donald" has been saying.
Valkpilot
Corinth, Texas
« Reply #21 on: September 07, 2015, 05:16:26 PM » |
Well, back to the slab.
I took the bike to work last week and it sat in the sun all day. Some sort of extreme paint/filler shrinkage occurred. (Did you know that black surfaces will reach 150° F in full sunlight?)
So, I'll be revisiting the repair. For one thing, I think I need to reinforce and stabilize the seams from the back side.
Not concerned that it's a fatal disease, just more work to get to the cure.
Paint is still shiny though!
« Reply #22 on: September 07, 2015, 05:21:41 PM » |
Fudgie puts leather condoms on his bag lids.
Valkpilot
Corinth, Texas
« Reply #23 on: September 07, 2015, 05:22:48 PM » |
Fudgie puts leather condoms on his bag lids.  Strangely, I find that completely in character.
Yfx4
« Reply #24 on: September 14, 2015, 09:58:54 AM » |
Just a thought....the filler is meant for metal? could the ABS expand/contract differently than metal and cause the problem? There are plenty of black cars with filler that have no problems....
Just thinking outloud....
1999 Valkyrie Interstate 2007 VTX 1800R DW rides a 2010 Spyder RT
Valkpilot
Corinth, Texas
« Reply #25 on: September 14, 2015, 11:23:56 AM » |
I did not use body filler such as Bondo. It's all ABS plastic/cement with tiny amounts of glazing putty to fill in pits and to level a couple of raised edges. It behaved more like there was unevaportated solvent yet in the repair. Hard to believe since I took such a long time to complete the project, but possible. I think the bigger issue is that I need to reinforce the seams more to prevent movement.
Yfx4
« Reply #26 on: September 14, 2015, 12:00:50 PM » |
I did not use body filler such as Bondo. It's all ABS plastic/cement with tiny amounts of glazing putty to fill in pits and to level a couple of raised edges. It behaved more like there was unevaportated solvent yet in the repair. Hard to believe since I took such a long time to complete the project, but possible. I think the bigger issue is that I need to reinforce the seams more to prevent movement. Gotcha. I am watching closely since I have some repairs to make.
