February 10, 2026, 10:27:08 PM
pingel petcock 1311CH
Topic: pingel petcock 1311CH (Read 1019 times)
westnek
August 26, 2015, 05:46:17 AM »
hi friends -is this the correct part number for 98 valk std. 1311CH-pingel---I'm thinking of changing with the next tank removal, no problems so far with OEM but 125000 kilos, however getting concerned about hydrolock=so ? is - what size fuel line and from petcock to what carburetor OR carburetors do I hook it to ?? is this a single hose connection and is it difficult to hook this into carb's with out too much trouble [ any hints ] thank you all, West '' a great club here ''
Last Edit: August 26, 2015, 05:53:29 AM by westnek
Re: pingel petcock 1311CH
August 26, 2015, 05:53:51 AM »
Look at the part on line, look at how the present one is connected, it's self explanatory
westnek
August 26, 2015, 05:59:26 AM »
thanks chris I forgot to mention another concern is that ??do I need a front outlet or left outlet OR whatever it takes when I order this part ,as ive seen different outlet sides so just wondering and don't want to end up with wrong set up thanks take care
August 26, 2015, 06:58:30 AM »
The 1311CH is the # listed for Pingel in their catalog.
It has been reported that they have both a manual and vacuum model as well as different valve operation.
The manual model they sold years ago [ I think the number is still 1311, its been about 15 years] is an easy replacement but the valve works backwards. In other words, rear pointing is on and front pointing is off. But, as in most things its not a problem once used to it.
BigMac (SoCal)
Moreno Valley, California
August 26, 2015, 08:01:19 AM »
This is the correct Pingle petcock.
http://www.amazon.com/Pingel-Designer-Power-Flo-Petcocks-Forward/dp/B000GZHZ48
Fazer
August 28, 2015, 12:22:34 PM »
I had to replace the OEM petcock on my 89 Shadow and bought the Pingel. Great product. If it ever needs replacing on the Fat Girl, it'll be a Pingel--pricey, but a good example of the lesson I learn over and over, that you get what you pay for.
Nothing in moderation...
