November 20, 2025, 12:09:29 AM *
Author Topic: U-Joints  (Read 1909 times)
db46
« on: September 05, 2009, 11:13:31 AM »
Any short cuts for removing the u-joints?
« Reply #1 on: September 05, 2009, 11:42:53 AM »
Well, If a shortcut would be NOT having to remove the swing arm....yes there is:
You have to remove the rear wheel and final drive/driveshaft
Next you remove the chrome cover that hides the rear brake slave cylinder, unbolt the cable keeper for a couple big wire bundles right in that same area and then un bolt the master cylinder and move it out of the way
Now you can get the boot away from the motor, use a large blade screwdriver to push the u-joint off the output shaft and then work it out of the gap between the motor and the frame......
Its not that hard
db46
« Reply #2 on: September 05, 2009, 11:52:06 AM »
Thanks for the advise cooldude
DFragn
« Reply #3 on: September 05, 2009, 03:14:03 PM »
Actually it's easier to remove it from between the swingarm & the boot.
It's not hard.
Except for reattaching the boot at the swing.
Use a little grease or alcohol. It'll be easier to attach.
LadyDraco
TISE
« Reply #4 on: September 05, 2009, 04:50:21 PM »
It's an easy job....Just take your time...
The boot is easy as well ..
I like to roll it back on it's self ...
And it almost jumps right on...
I have done myshare of them...
This  is  the  way
Mr.BubblesVRCCDS0008
« Reply #5 on: September 05, 2009, 04:52:34 PM »
Go to rattlebars.com and read the write up on removing. I have learned a trick to getting the boot back on the swingarm is to wait until the bike is off the jack and leaning on the kickstand. This lessens the angle on the arm and allows more room to work without the jack in the way. Lube it a little and work form the high side. Needlenose pliers also help if you have meathooks like mine. Wink
