February 10, 2026, 10:26:47 PM
98 tourer noise
Topic: 98 tourer noise (Read 793 times)
slabghost
Eastern Ohio
98 tourer noise
August 31, 2015, 05:58:13 AM »
I must be getting used to the bike although it's still new to me. I'm getting a noise usually under load at random rpm. It sounds almost like quietly pouring pea gravel. It lasts only a few seconds at a time but is very annoying. Then on my last ride with it I got intermittent buzz feel in the footpegs. It seemed to alternate with the noise. Once home and stopped it smelled like hot rubber.
Any ideas here?
Politicians like diapers need changed often. And for the same reason.
If you aren't a liberal at 20 you have no heart. If you aren't conservative at 30 you have no brain.- Mark Twain
Hot air is great for balloons but worthless in conversation.
Re: 98 tourer noise
August 31, 2015, 06:08:11 AM »
Put the bike on a lift (rear) try to make the wheel move side to side. If it moves it will be a slight "tic tic" feel. That would be a bad wheel bearing.
Marinakorp
King of Prussia, PA
Re: 98 tourer noise
August 31, 2015, 06:27:57 AM »
check your front tire for uneven wear... and then the rear rear.
I would rather be judged by 12 than carried by 6
Re: 98 tourer noise
August 31, 2015, 07:00:51 AM »
Check under the front fender. There's a couple pieces of lining under there for noise suppression and they sometimes will come loose. When the front tire rubs against it, it will give similar noises and also smell like hot rubber. Easy stuff checked first!
