February 10, 2026, 10:27:05 PM *
Author Topic: Question on Balancing Wheels  (Read 880 times)
lljjmm
« on: September 04, 2015, 01:53:04 PM »
Is it best to  balance the wheels with rotors on or not?  Ya, one of those questions.
« Reply #1 on: September 04, 2015, 02:17:43 PM »
Only if, when riding the bike, the rotors will be on.
« Reply #2 on: September 04, 2015, 03:11:53 PM »
 Grin
Pete
« Reply #3 on: September 04, 2015, 03:27:51 PM »
Yes and on the rear with the rubber cush blocks installed and any stem caps you intend to use.
« Last Edit: September 04, 2015, 05:01:23 PM by Pete » Logged
F6Dave
« Reply #4 on: September 04, 2015, 07:10:12 PM »
You can also try dynamic balancing, with something like Dyna Beads.  They are simple to install.  I was a skeptic but have to admit they work very well.
« Reply #5 on: September 04, 2015, 07:58:26 PM »
+1
F6Dave
« Reply #6 on: September 05, 2015, 04:32:44 AM »
Let me elaborate.  The front wheel on my Interstate was always difficult to balance.  There was always a speed range where I'd get a little vibration.  These massive Valkyrie wheels can have light areas that make balancing very tricky.  I've read of some with enough porosity to allow slow air leaks.
At first I thought Dyna Beads were snake oil.  Then I read truck drivers had been doing this for years, with lead shot, BBs, even sand.  The concept actually makes sense.  And it works.  I pulled the weights and put the beads in that front tire.  It was glassy smooth at all speeds.  I'm a believer now.
