January 29, 2026, 03:11:39 PM *
Author Topic: Any problem with mixing these?  (Read 1761 times)
doubletee
VRCC # 22269
Fort Wayne, IN
« on: September 06, 2009, 04:54:03 AM »
The one on the right says "Synthetic." One on the left only says "High Performance." I'm thinking they're the same, just different packaging for marketing purposes.  BTW, are new brake pads normally a little noisier until they get seated? The new fronts seem to be dragging a lot more, going by the noise. However, the wheel spins freely, so I don't think they're hanging or binding:
« Last Edit: September 06, 2009, 05:06:58 AM by doubletee » Logged
« Reply #1 on: September 06, 2009, 07:55:12 AM »
Yes you can mix those two fluids. You cannot mix DOT5 silicone with DOT4.
sugerbear
wentzville mo
« Reply #2 on: September 06, 2009, 07:56:35 AM »
brake fluid is cheap, why bother. flush and fill with fresh.
when in doubt i throw it away and buy new.
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #3 on: September 06, 2009, 08:18:44 AM »
That's essentially what I did, but just wanted to make sure any residual old stuff wouldn't cause a problem. Thanks for everyone's response.
BTW - the noisy fronts quieted right down after a little test ride.   cooldude
