November 26, 2025, 11:36:32 AM *
Author Topic: Pingel Install  (Read 943 times)
pais
One more turn should do it!
Kent, Ohio
« on: September 06, 2015, 05:39:03 AM »
  Good morning all, I was perusing the search engine. Could not find what I was looking for. Curious if there is any tips, tricks or warnings, for when I change stock PC to a Pingel? Seems like I've seen little bits and pieces while reading some posts. Nothing really definitive. Is it so simple I'm worried about nothing?
« Reply #1 on: September 06, 2015, 05:52:03 AM »
Pretty much plug and play. The Pingle has 5/16" outlet while the fuel line is 8mm.
Part of your pre-flight/post-flight mental check list will be to now turn on and then turn off the fuel. Thats probably the hardest thing for most folks to do when making this change.
Michvalk
Remus, Mi
« Reply #2 on: September 06, 2015, 06:49:59 AM »
There are a few things. The reserve fuel will be smaller than the stock. You can extend the tube a little to fix that. Make sure that the tank filter fits in snug. There are endless threads on replacing the petcock, just need to start your search on the main tech page cooldude
« Reply #3 on: September 06, 2015, 09:10:37 AM »
Yes
westnek
« Reply #4 on: September 06, 2015, 01:56:34 PM »
just installed pingel 98 valk std--  and I syphoned tank;i left a bit of fuel in - I tilted tank forward to thread  pingel petcock in  made sure its  in off position, then leveled tank and vent tube on tank drained out fuel ==is that normal because  I tilted tank forward did this cause fuel to run out of  hose fitting  and will it be ok now installed on bike = I put a hose on vent tube form tank and tied a knot in it to get things together ===?????would I have knocked a vent hose off in the tank by inserting a syphon hose in side  if I did up set a vent hose in the tank can I re-attach it  to where ever ??  suppose  it connects around the filler cap-not sure ==any help thanks   folks
westnek
« Reply #5 on: September 06, 2015, 02:05:54 PM »
Yes
chris can you read my  topic reply   I sent on this  post    I didn't syphon all the fuel, tilted  tank installed  pingel  and when I leveled tank  fuel poured out of vent hose pipe ;;was it because tank was tilted and fuel ran back or did syphoning tank knock off  a vent hose in side tank  ==thanks  chris  I also sent a messege to  Patrick  =hope you guys can help me here   thank you so much
« Reply #6 on: September 06, 2015, 02:16:48 PM »
Yes
All sounds normal to me, remember to turn it off each time you stop.
