February 11, 2026, 12:13:47 AM *
Author Topic: Engine question - I think I know the answer  (Read 1648 times)
Paladin528
« on: September 10, 2015, 05:04:09 AM »
Ok I have a new issue and I think I know the answer but input would be welcomed as to where to start.
This morning I put a full tank of gas in the fat lady and headed out to work.  It is a cool morning but no "Cold"
When I stopped at a light sitting there I notice my idle had increased to around 1250rpm. I gave the throttle a blip and it settled back to 900 rpm but is wavering (it has always wavered a bit but I have only owned it since Spring) it then crept back up a bit.
I also noticed that when I blip the throttle it takes a little longer to settle taking a few seconds to slow down. (clutch in and stopped)
I am leaning towards a Vacuum leak but not sure where to start.  All of the carb boots are secure and tight.
So... I am thinking maybe intake runner o-rings, vacuum lines.
Anything else I should look at?
No, it has not been desmogged and I was waiting for the end of the season to tackle that.
Pete
« Reply #1 on: September 10, 2015, 05:18:49 AM »
As you surmised an intake or vacuum leak would  be my first check.
« Reply #2 on: September 10, 2015, 08:42:19 AM »
If it HAS NOT been desmogged you have a rat warren of vacuum lines under the air box. And the heat cool cycles dry out the hoses. If you can't legally desmog replace vacuum lines with a high quality silicone lines. RIDE SAFE.
« Reply #3 on: September 10, 2015, 09:36:23 AM »
check the rubber caps on the intake manifolds, a known problem.
silicon is not the best material to use.
Paladin528
« Reply #4 on: September 10, 2015, 09:41:53 AM »
Ok since we are all in agreement.  What is the best vacuum line to use?  I was going to go with the Silicone lines (actually was gonna do red ones to match the paint).
What are the thoughts on what to use and the best place to procure, preferably in Canada.
« Reply #5 on: September 10, 2015, 10:18:07 AM »
My thoughts concern the throttle cables and the adjustments.  When working the throttle you should hear the cables 'snap' to the stop which is just to the rear the idle speed adjuster.
Paladin528
« Reply #6 on: September 10, 2015, 10:30:37 AM »
Throttle operation is normal.  Even if I twist the throttle forward and "pull" the throttle to the stop the same thing happens.
like I said in the first post If I blip the throttle it slowly recovers to 900 rpm then will drift up to 1250 or so and just wobble around there.  not a stable idle either it is +- 50 rpm.
« Reply #7 on: September 10, 2015, 12:29:22 PM »
silicone is actually great if the following are avoided
Generally, silicones are attacked by most concentrated solvents, oils, acids and dilute sodium hydroxide.
look for a chart for its resistance to gasoline and more properties.
« Reply #8 on: September 10, 2015, 12:37:52 PM »
If my Tourer ever gets here, on my list of mods is, desmog.  I'm going to plug the runner nipples differently this time.  This thread made me think, why shouldn't I just use a blob of silicon Goop, that all-purpose adhesive and glue?  I've used it a lot to do things like attach LED fixtures to the bike - Seems a blob of that on the nipples, would stay in place, wouldn't crack, and would be easy to remove when I want to sync the carbs. Why not?
Steve K (IA)
Cedar Rapids, Iowa
« Reply #9 on: September 10, 2015, 12:57:34 PM »
Do you have the stock petcock?  Have you replaced the cover set?  The vacuum leak could be there.
My I/S had the same symptoms.  Was convinced I had a vacuum leak.  Changed the vac hoses that go from the pair valve and split off to the 2 intake runners.  In 16 seasons, they still looked new.  Not brittle, no cracks and no holes.  I replaced them anyway.  I replaced the intake runner o-rings a few years ago...checked them, they looked new and no apparent signs leaking but did have a new set of o-rings and replaced them anyway.  Put the tank on and was going to use my new Digi Sync to sync the carbs and couldn't get vacuum to hold at the petcock.  Apparently the diaphragm has a hole or tear in it.  I haven't torn into it yet, the cover set is to come yet today.  But that has to be where my problem is.
States I Have Ridden In
« Reply #10 on: September 10, 2015, 01:15:36 PM »
    Mark-Attic Rat uses brass threaded plugs where you are talikn bout putting the goop. Just throwin it out there as an F Y I. RIDE SAFE.
« Reply #11 on: September 10, 2015, 01:22:08 PM »
how are your silicone lines holding up? I remember yrs ago somebody had them and they didn't last more than 1 yr. maybe they used low quality hence u saying high quality.
« Reply #12 on: September 10, 2015, 03:16:54 PM »
        I myself have done the desmog on my Phatt Ghurl.  cooldude RIDE SAFE.
Paladin528
« Reply #13 on: September 10, 2015, 03:25:07 PM »
I just gave a suck on the peacock vacuum line. Guess what. It does not hold vacuum.   I will order the cover set tomorrow and start there.
I wouldn't mind doing the rest anyway but now I may be able to wait a bit
« Reply #14 on: September 10, 2015, 05:05:12 PM »
silicone is poor with gasoline.
http://www.efunda.com/designstandards/oring/oring_chemical.cfm?SC=none&SM=Silicone#chem
best materials for gasoline
http://www.efunda.com/designstandards/oring/oring_chemical.cfm?SM=none&SC=Gasoline%2C%20Automotive#mat
Buna-N is the oem o-ring material. can only be used once or twice due to how it takes a set.
« Last Edit: September 12, 2015, 08:40:55 AM by CA » Logged
Paladin528
« Reply #15 on: September 11, 2015, 09:56:26 AM »
Ok so I priced the intake runner o rings at my local Honda dealer. $8 bucks Canadian a piece. A little steep for an o ring.
I know some have posted aftermarket replacements but I can't find it.  Please post a link.
I am also looking for a cover set for the petcock if I can find one cheaper
Steve K (IA)
Cedar Rapids, Iowa
« Reply #16 on: September 11, 2015, 10:41:14 AM »
O-rings....
Advance Auto Parts
part # 64628.1  $1.59 ea.   size 28mm x 34mm x 3mm
Check your hardware stores or farm stores for this size.
For petcock.
Partzilla.com    16953-MBZ-B51 COVER SET,rooster   $28.84  before shipping charge.
« Last Edit: September 11, 2015, 11:02:14 AM by Steve K (IA) » Logged
« Reply #17 on: September 11, 2015, 11:46:22 AM »
If you are going to get the o-rings at a hardware or auto store make sure they are viton not silicone. I would recommend Redeye for them. And on your cover set get the OEM some have had issues with the K&L.
DenverDave
Out past Mars ain't no speed limit -Mojo
« Reply #18 on: September 11, 2015, 07:01:32 PM »
Intake seals
$9.99 for a set of six
http://www.carolinabikeandtrike.com/ORings.htm
$11.68 for a set of 6
http://redeye.ecrater.com/c/414983/carb-intake-seal-kits
Hope this helps
Dave
I'm in the process of replacing all six, noticed some leaking after the Labor Day Memorial ride.
1999 interstate green/silver
Denver, Colorado
VRCC#32819
VRCCDS#0238
Paladin528
« Reply #19 on: September 13, 2015, 10:18:50 AM »
thats the one.  Thanks a million.  Ordered....
