February 11, 2026, 12:14:03 AM *
Author Topic: clicking noise when applying front brake  (Read 972 times)
Bronxboy
Tampa Bay FL
« on: September 13, 2015, 03:34:00 PM »
Brakes are all new, brakes are working fine, but I am getting a clicking noise when I apply the front brakes. Back brakes are quite and normal?  Sad
« Reply #1 on: September 13, 2015, 03:59:05 PM »
Springs (clips)  in place?
longrider
Vernon, B.C. Canada
« Reply #2 on: September 13, 2015, 04:02:08 PM »
When you replaced the brake pads did you remove the tire?  If so make sure the left fork leg is in its proper position or the caliper will rub on the rotor.  A quick check.  looking down the leg from the top the axle head should be pretty much flush at the top and bottom of the leg
warren
N8171S
Marlboro, Mass
« Reply #3 on: September 13, 2015, 04:25:03 PM »
Clicking is not abnormal as the pads are free floating.
« Reply #4 on: September 13, 2015, 04:57:17 PM »
This.
sdv003
Prescott Valley, AZ
« Reply #5 on: September 13, 2015, 09:13:09 PM »
Spring clips in place and not worn?  The pads might be hitting the pin when you apply the brakes if the clip is old/worn/bent.  Try replacing the clips or maybe bending them a bit to hold the pad in place better.
Bronxboy
Tampa Bay FL
« Reply #6 on: September 14, 2015, 07:14:00 AM »
Thanks all, I am on a trip and soon as I have time I will take a peek  cooldude
