March 14, 2026, 11:59:01 PM
1800 Tech Board
For those on stock tires - UP YOUR TIRE PRESSURE
Topic: For those on stock tires - UP YOUR TIRE PRESSURE (Read 2931 times)
dinosnake
September 13, 2015, 05:34:20 PM »
I just came back from today's ride, which included minor 2-lane twisty state roads, major state road with high speed twists and even a 45 MPH roundabout (traffic circle) and major parkways. I ran the tires today 38 front / 42 rear and the bike handled far more neutrally and reassuringly. I should have realized this before: Honda claims that the new Valkyrie has a 50-50 weight distribution...
so why such a dramatic difference in recommended front vs rear air pressures?!
The difference is noticeable, and I'm a lightweight at 148 pounds (usually about 142). For you big guys, 200-250 pounds, the 36-pound front must be flexing the carcass all over the place. My guess is that the Ford mentality is at work here: they set the recommended pressure based on comfort, not on best performance. Up your pressures and see what happens!
AdrianR
Far North Chicago Burbs'
Re: For those on stock tires - UP YOUR TIRE PRESSURE
September 13, 2015, 06:18:24 PM »
I did, several times...I weigh a buck 75 or so...The Honda recommended pressure made the bike handle like a sponge to some degree...41 psi front and back was far better...but then constituted a rough ride and tires that wouldn't stay planted well unless the concrete was exceedingly clean...and without cracks...
Those tires SUCK...
dinosnake
September 13, 2015, 07:31:31 PM »
Midline Dunlops have a habit of being that way, it seems. I've had worse, though.
havoc
VRCC #36861
Calgary, Alberta CA
September 14, 2015, 04:48:20 AM »
i'm 210lbs and running 38-40 in the front, 42 in the back. so far so good. Come time to replace the tires though, i DEFINITELY won't be buying these same tires.
"Not all those who wander are lost" - J. R. R. Tolkien
