February 11, 2026, 12:13:57 AM *
Author Topic: oil seal on output shaft  (Read 892 times)
« on: September 13, 2015, 05:39:22 PM »
Has anyone ever had the oil seal go bad on the output shaft or the o ring? My brothers bike that we fixed a hydrolock on last summer is now leaking oil out of this area. We cleaned it all up and rode it a few miles and determined this is where it was comimg from. So now our plan is to remove the rear end driveshaft and u joint to get the cover off and replacethe seal and o ring. I have not read anything about this before so it must not be that common.
Punisher
No, not vengenance. Punishment.
« Reply #1 on: September 14, 2015, 11:50:03 AM »
Did you replace the seal when doing the hydro-lock repair?   With the age on these bikes now anytime something like that gets disturbed it can start leaking, a good idea to replace it.
If you did replace it, a chance you nicked it during the install over the shaft?   Did you put a little grease on the seal lips?
Check the bolts holding the cover over that shaft/seal (three I think).    I know of a leak caused by one of those bolts not being tight.   You may be able to check those bolts without having to pull the rear-end down.
Daniel Meyer
The State of confusion.
« Reply #2 on: September 14, 2015, 01:23:21 PM »
It's an easy fix. All the ones I've seen failed had the little seal spring off the lip (bent lip over during install).
CUAgain,
Daniel Meyer
« Reply #3 on: September 14, 2015, 01:54:08 PM »
We did not replace it during the hydrolock fix. Got the seal and o ring ordered. Talked to Trout Dude last night and he said if oil is inside the boot it's the seal, if outside the boot its the o ring. I think it may just be the o ring but got both just to do while we are at it.
Daniel Meyer
« Reply #4 on: September 14, 2015, 02:04:00 PM »
May want the boot too. Oil softens them up quickly and they are not expensive.
CUAgain,
Daniel Meyer
« Reply #5 on: September 14, 2015, 03:39:11 PM »
 cooldude that was a new boot last summer, but what the hell, I'll order one just for good measure
da prez
Wilmot Wi
« Reply #6 on: September 15, 2015, 12:05:25 AM »
   Did you clean the drain holes in the drive shaft.
                                                    da prez
« Reply #7 on: September 15, 2015, 02:47:38 AM »
                                                    da prez
What drain holes?
