Yfx4
« on: September 15, 2015, 07:12:39 AM » |
several searches came up empty.
Other than riding it dry, what is the best/easiest way to empty the tank of fuel?
1999 Valkyrie Interstate 2007 VTX 1800R DW rides a 2010 Spyder RT
« Reply #1 on: September 15, 2015, 07:53:49 AM » |
Syphon Hose
« Reply #2 on: September 15, 2015, 07:55:16 AM » |
If it's good enough gas to run, why do you want to empty it?
Yfx4
« Reply #3 on: September 15, 2015, 08:10:49 AM » |
Because I wrecked it and I don't want the gas to sit while I fix it. I will empty the tank, put in stabile then run it to make sure the jets don't gum up.
Paladin528
« Reply #4 on: September 15, 2015, 08:44:04 AM » |
REmove the tank. Apply vacuum to petcock. catch fuel in bucket.
« Reply #5 on: September 15, 2015, 09:33:58 AM » |
This sounds like a great idea... taking off the petcock and trying to get it to all come out didn't work so well for me, there's channels and stuff inside there or something... the place where the vent tube comes out the back for example, that's not just a place to hook a hose up to a hole in the tank... -Mike
Valkpilot
What does the data say?
Corinth, Texas
« Reply #6 on: September 15, 2015, 11:23:27 AM » |
Both the siphon and the petcock suggestion will work to get most of it out, but as noted, there will be a signficant amount that can't be extracted this way.
You've got an IS, so you could remove the fuel sender and have another opening to get some more out.
You still won't get it all. My suggestion would be that once you've gotten every drop you you from the above methods, leave it outside without cap or petcock and evaporate the rest.
Yfx4
« Reply #7 on: September 15, 2015, 12:04:36 PM » |
Great ideas!. I figured I could never make it totally dry without evaporation. Thank you all
Cracker Jack
« Reply #8 on: September 15, 2015, 04:18:15 PM » |
I've has good success getting the last bit out by putting an absorbent rag on the end of a wire (coat hanger) and holding the tank so the last bit is in a corner accessible to the filler opening.
shortleg
« Reply #9 on: September 17, 2015, 04:22:05 AM » |
I used my Mity Vac to get Vacuum on tank and the put a longer piece of fuel line on tank and turned valve to On and drained into a gas Can. shortleg[Dave]
dragonslayer
« Reply #10 on: September 17, 2015, 07:07:48 AM » |
You might think this is crazy but when I cleaned my tank out I took a small shop vac and wedged the hose in the filler hole,put the other end in the outlet side of vaccum and turn it on.It will force warm air into the tank so do it outside in fresh air and it will totally dry the inside of the tank.Put about 2 cups wd40 or some other water despersent in the tank and roll around to coat the inside.Forgot to say REMOVE petcock before turning on the vaccume.Really easy way to evaperate gas from the tank.
2k IS 98 Tour 2001 Stand
Yfx4
« Reply #11 on: September 17, 2015, 08:38:43 AM » |
Good idea!
I planned to siphon the bulk of it, then remove the tank, dump the rest. Th vacuum idea will make quick work of the little bit left. Thanks for the WD40 idea!!
« Reply #12 on: September 17, 2015, 09:21:21 AM » |
I can't help but think the vacuum cleaner idea is a recipe for blowing up.  -Mike
dragonslayer
« Reply #13 on: September 17, 2015, 04:44:26 PM » |
« Reply #14 on: September 17, 2015, 05:24:20 PM » |
Sounds like you're sucking gasoline fumes from the filler tube and blowing them back into petcock with a piece of electrical equipment... maybe I didn't understand... -Mike
« Reply #15 on: September 17, 2015, 05:42:04 PM » |
When I sold my IS tank, I dumped the gas, gave it 24 hours open to evap, then used a oil fogging agent and sprayed inside the tank, be fore shipping. I don't recall my smell of gas, and also would leave it free of rust.
dragonslayer
« Reply #16 on: September 18, 2015, 07:00:47 AM » |
NO,not sucking the fumes.The other end of the vaccume hose goes into the discharge port of the vaccum which blows warm air into the tank.No boom just fumes escaping from petcock hole and totally drying the inside.A small shop vac works best.
Paladin528
« Reply #17 on: September 18, 2015, 10:45:37 AM » |
Drain as much as you can the dump in some isopropyl alcohol and swish it around. Drain that out and it will evaporate faster than the Gasoline.
« Reply #18 on: September 18, 2015, 12:46:56 PM » |
I will soon be brazing the bung on my tank for the belly tank. Incidentally, there's a guy on youtube who welds on his car tank with gas in it. He got away with that by running exhaust from another engine into the tank to displace the air with inert gas. Even so, the hole where he was welding, the fumes ignited outside the tank - yellow flame several inches long. To me, kinda crazy, don't think I'll try that even if it seems plausable.
Anyway, the process given in several places varies some, but it amounts to siphoning as best as possible, then actually filling the tank with water a couple times. Then using argon gas - that's inert gas used in MIG and TIG welding - to displace the air inside before welding. It's dangerous w/o getting the oxygen displaced. Even if you think it's totally empty, some gas permeates the metal pores and gasses out when heated, and explodes like a bomb.
I'm not doing the water thing. But I will siphon, then remove the filler bezel and invert the tank. Then air it out with a vacuum blower hose for 20 minutes to evaporate what remains. Then displace the air inside with argon for 10 minutes, then keep the argon running while brazing. Silver Shield (Argon/CO2 mix) is heavier than air, so theoretically running it into the tank will displace the air up, want to have an opening upwards. In practice, doesn't matter much because it's only slightly heavier than air - it will mix and exit in any direction anyway.
