February 11, 2026, 02:05:01 AM *
Author Topic: complete carb rebuild kit  (Read 6077 times)
andycz1
Glendale, Az
« on: September 18, 2015, 07:40:59 AM »
My bike sat most of the summer, now 3 of the carbs are leaking fuel. looks like it's time to rebuild the carbs. who sells the most complete kit?
I want to get all the gaskets and o rings in one order.
any suggestions once I pull them would also be appreciated.
thanks,
« Reply #1 on: September 18, 2015, 07:48:17 AM »
I think Redeye sells a kit for Valkyries... redeye stuff is supposed to be
real good...
http://redeye.ecrater.com/p/2063876/carburetor-gasket-kit-viton-gf
BonS
Blue Springs, MO
« Reply #2 on: September 18, 2015, 02:26:48 PM »
Redeye sells a lot of the parts you'll need. However, you'll have to look elsewhere to get float needles. One source is here: http://www.amazon.com/gp/product/B001KOD732?psc=1&redirect=true&ref_=oh_aui_search_detailpage.
If you need slo/idle jets a good source is here: http://jetsrus.com/a_jet_kit_street/honda_1500_valkyrie.htm.
My best advice is to not skip replacing the float needles. Period.
« Reply #3 on: September 18, 2015, 03:21:49 PM »
Try letting it sit with gas in bowls and see if the rubber doesn't swell back up and stop leaking first.
« Reply #4 on: September 19, 2015, 08:04:36 AM »
There is nothing to rebuild in the Valkyrie carburetors. Have you ever drained a little bit of fuel from each bowl. That's about the only maintenance needed. if you're using ethanol enriched gasoline, a regular dose of an additive is highly suggested. Neglect is the biggest cause of carburetor problems.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #5 on: September 20, 2015, 10:47:33 AM »
real good...
Don't forget the bowl gaskets.  Redeye sells them separate.  I don't know why this is, they should be included with the carb gasket kit.
« Last Edit: September 20, 2015, 10:49:39 AM by Steve K (IA) » Logged
States I Have Ridden In
hukmut
Stone County, Mississippi
« Reply #6 on: September 21, 2015, 02:30:51 PM »
AND the float needles.
