February 11, 2026, 02:06:31 AM *
Author Topic: Need help with question  (Read 1113 times)
Aries
« on: October 03, 2015, 04:31:55 PM »
Alright fellas
Is there some trick to pulling the starter?  I've removed three bolts and tried to pull the starter motor back but it still feels like something is locking it in internally. What am I missing? Before I break out the XL screwdriver ( for leverage ), I thought I would hit the Valk group up.
« Reply #1 on: October 03, 2015, 04:33:39 PM »
No help here as the starter is not something that usually goes bad.
GiG
NEAR the "In 'n' Out Burger"
« Reply #2 on: October 03, 2015, 04:48:33 PM »
Not so much a trick as finesse.
Leave the XL in the tool box.
You cannot change the starter until the starter is ready to change.
Be the starter.  coolsmiley
Everything is - Nothing is .
(send it to OSS)
This isn’t Rocket Surgery
« Reply #3 on: October 03, 2015, 04:53:27 PM »
2funny I had to be the alternator once.
Aries
« Reply #4 on: October 03, 2015, 04:59:41 PM »
When I was trying to start the bike last time, I heard a grinding noise. Now when I run the engine a pushe the starter while the bike is idling, I can hear what sounds like ball bearings bouncing around. If it's not the started what else could it be?
« Reply #5 on: October 03, 2015, 05:02:02 PM »
Uh don't push the starter button with the engine idling !
Earl43P
Farmington, PA
« Reply #6 on: October 03, 2015, 06:34:20 PM »
When I was trying to start the bike last time, I heard a grinding noise. Now when I run the engine a push the starter while the bike is idling, I can hear what sounds like ball bearings bouncing around. If it's not the started what else could it be?
What you are hearing is an over-running clutch. It keeps the engine from driving the starter if the solenoid were to get welded contacts. It is not necessary or prudent for you to test that in the manner you describe. But yours is working as designed.
I haven't replaced a 1500 starter, but the 1100 starter has nothing but an o-ring holding it in that crusty bore once you remove the bolts. Spray some lube in there.
« Last Edit: October 03, 2015, 06:36:47 PM by Earl43p » Logged
08 Goldwing
21 KTM390A
99 Valkyrie IS Sold 5/5/23
VRCC #35672
VRCCDS # 0264
When all else fails, RTFM.
baird4444
« Reply #7 on: October 04, 2015, 07:35:29 AM »
              http://www.valkyrieforum.com/bbs/index.php?topic=53575.0
    - ya gotta be SOBER!
     -Cody Baird
Firefighter
Harlingen, Texas
« Reply #8 on: October 04, 2015, 08:15:12 AM »
The Clymer manuel says to remove the seat and the center cover (for clearance), but after re-reading your post I guess you have not moved the starter at all. The o-ring area might be holding tight, I would be gentle.
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
