February 11, 2026, 02:07:35 AM *
Author Topic: Dan-Marc with stock petcock  (Read 1087 times)
Fazer
« on: October 05, 2015, 12:35:39 PM »
Does it make sense to add the Dan-Marc electric shut off and use the stock petcock?  A search of the forum results in a lot of info when going to the Pingle unit, but I would like to service the stock unit, and add the Dan-Mark when I de-smog.  Speaking of, can the Dan-Marc be installed without desmoging, or is the space un-available without removing the gismo under the the airbox?
Nothing in moderation...
big poppa pump
San Antonio, TX
« Reply #1 on: October 05, 2015, 12:42:03 PM »
I am using the stock petcock with a AFC-111 electric shut off on my yellow bike. I have however modified my stock petcock to remove the vacuum function and use it manually.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
TJ
Lake Placid , Fl.
« Reply #2 on: October 05, 2015, 01:33:02 PM »
Yes , you can use it with the stock petcock...
You don't have to desmog , but why not do it...
« Reply #3 on: October 05, 2015, 01:43:01 PM »
DITTO, I have two bikes setup that way. I like the safety feature Honda built into the petcock even though it maybe a problem if not working properly.
My rides:
