February 11, 2026, 02:07:31 AM *
Author Topic: Re-installing carb bank  (Read 760 times)
pais
One more turn should do it!
Kent, Ohio
« on: October 08, 2015, 01:53:53 PM »
   When I removed carb bank I removed all the intakes. Wondering whats the best way to re-install? Hang the intakes on the carbs or mount intakes to heads? While I'm at it. I got the intakes mixed up. Which go where?  One of the few things I did not take pics of. uglystupid2
    Will be soooo glad when I'm done. Hell for that matter you guys will be glad when I'm done! Never did anything like this before. All uncharted ground. I already have the itch for another Valk. I'm sure it will need carb attention. I will feel more at ease then Roll Eyes
« Reply #1 on: October 08, 2015, 02:10:59 PM »
When I did mine I put in the carbs without the intakes. Then put one in at a time. They are all the same . If you have the stock petcock make sure the line reaches, but it doesn't matter which one its on.
« Reply #2 on: October 08, 2015, 02:56:43 PM »
install carb bank, remove airbox hold down bolts if not done already, then left up carbs and install intakes.
see manual.
all the intakes are mirrors of each other.
