January 29, 2026, 03:09:48 PM *
Author Topic: I think this will work  (Read 1972 times)
« on: September 07, 2009, 06:49:01 PM »
but, does anyone know for sure if OEM Valkyrie handlebar risers will change out for VTX 1300 risers.  I know ours has a dual (one piece) clamp on top and the VTX has singles (two clamps) but since the bars are the same diameter Im thinking Valk risers and VTX clamps should bolt up.  Anyone??
« Reply #1 on: September 07, 2009, 06:54:09 PM »
I would assume since they are both made by Honda they should change out.
Be sure and throw a blanket over the tank, otherwise you will be saying a few nasties..........
« Reply #2 on: September 07, 2009, 07:44:44 PM »
Yes.
I know that for sure on the handlebar end.  I strongly believe it on the triple tree end.
« Reply #3 on: September 07, 2009, 09:34:36 PM »
Thanks guys.......now I guess its off to the classifieds to see if anyone has a set of OEM Valkyrie risers laying around for my friend's VTX....she needs some "pull back"
6GUNR
« Reply #4 on: September 07, 2009, 09:46:09 PM »
I HAVE A PAIR OF OEM I CHANGED OUT FOR HD DEUCE RISERS.  REPLY IF INTERESTED.  6GUNR #3286
« Reply #5 on: September 08, 2009, 05:16:51 AM »
OK, I have to get with the VTX rider.  Thanks
Mr.BubblesVRCCDS0008
« Reply #6 on: September 08, 2009, 10:53:03 AM »
I'm running a set of risers off a VTX1800 on my   I/S  right now. A friend put taller risers on his VTX and since his stock risers were taller than my stock risers I put them on my bike. They give about 2 ins of pull back  over the stock valkyrie parts.
PAVALKER
Pittsburgh, Pa
« Reply #7 on: September 08, 2009, 03:11:29 PM »
Stock VTX 1800 C risers are good.... but NOT VTX 1800 R  Risers......  1800R Risers are much shorter than your stock Valk Risers.   I replaced my 1800R risers with 1800C risers and had some rivco risers I moved over to the Valk I/S.
And... sorry I am not sure about the 1300 risers, but I would imagine that they might.... but I would recommend the 1800C risers.
« Last Edit: September 08, 2009, 05:30:08 PM by PAVALKER » Logged
John
