February 11, 2026, 02:06:33 AM *
Author Topic: standard starter problem  (Read 861 times)
abiceman
« on: October 10, 2015, 11:49:24 AM »
So I pulled the switch apart cleaned with steel wool  no cleaner, still not working it will start if I cross over the solder points on the back of switch. am i missing something.
« Reply #1 on: October 10, 2015, 12:15:23 PM »
Is the little spring in there correctly?
« Reply #2 on: October 10, 2015, 12:36:13 PM »
Also sometimes the plastic will melt a little and deform.
« Reply #3 on: October 10, 2015, 12:58:31 PM »
It's not the switch, per say, but the springs in their holes that bind from old grease, that needs to be removed so they spring freely. This applies the upward pressure onto the plate to make contact.
I think this is the proper post, but there used to be pictures.
http://www.valkyrieriders.com/shoptalk/VSGPages/starterbutton.htm
abiceman
« Reply #4 on: October 10, 2015, 02:36:30 PM »
i cleaned the switch , springs and connection of all the grease and put it back togeather, but I did't regrease it.
