November 27, 2025, 01:39:08 AM *
Author Topic: What size allen key bolts for  (Read 1746 times)
« on: October 19, 2015, 07:40:43 AM »
the brake and clutch fluid reservoirs.
Previous owner has nearly stripped the heads.
Where do I get stainless steel?
indybobm
Franklin, Indiana VRCC # 5258
« Reply #1 on: October 19, 2015, 08:11:27 AM »
I believe that they are 4mm x 12mm flat head screws. Do you have a ACE Hardware close? Should be able to find stainless screws at most hardware stores.
So many roads, so little time
VRCC # 5258
« Reply #2 on: October 19, 2015, 08:13:44 AM »
Are you able to get the old ones out ?
I find a hand impact to usually work in these cases.
A little never-seize works when putting them back in.
« Reply #3 on: October 19, 2015, 08:18:25 AM »
I got the brake ones out early Fri morning to bleed the front brakes before the FCR ride.
Reservoir looked like it had melted milk chocolate inside it   Shocked
Clutch fluid looks good but I'll be changing that as well.
Hate to imagine what the rear brake fluid might be like.
Then the coolant and strip the rear wheel to to get that lubed up.
Oh the joy of "new" old bike purchase.
« Reply #4 on: October 19, 2015, 08:20:31 AM »
Thanks.
hukmut
Stone County, Mississippi
« Reply #5 on: October 19, 2015, 08:56:08 AM »
Friendly suggestion: suck out the crud fluid, put in fresh and then bleed the system until it flows clear, brake and clutch.  Supposed to be done every 3 years or so. Brake fluid is hygroscopic. In other words, it attracts moisture, thus the crud.
Ride safe. cooldude
« Reply #6 on: October 19, 2015, 09:09:31 AM »
Its a crap shoot on how, or if, things are/have been maintained isn't it.
« Reply #7 on: October 19, 2015, 09:18:26 AM »
Ride safe. cooldude
I do mine every year.
« Reply #8 on: October 19, 2015, 09:28:23 AM »
Sure is and even some of the best looking shiny bikes have been badly maintained.
« Reply #9 on: October 19, 2015, 05:35:20 PM »
Paul I don't know the size but I took mine to a local hardware (nut and bolt place) and handed him the screw and said I need 8 of these in stainless and he charged me $1.00 coolsmiley
Gideon
Indianapolis, IN.
« Reply #10 on: October 19, 2015, 07:29:18 PM »
There’s a bit of difference between Japanese Industrial Standard (JIS) Screws and the American Phillips style heads. That's why they are so often striped.
chris1998
« Reply #11 on: March 27, 2016, 10:04:27 PM »
If you can't find stainless steel screws in a Home Depot, Lowes, or any hardware store, try a boating store.
Tourus
Spring Hill, fl
« Reply #12 on: March 28, 2016, 06:39:50 AM »
   I am lucky to have an Ace Hardware 1 mile from my house. They have a good selection of metric stainless steel bolt so take the one you got out with you and use their sample board and screw it in until you find the right tread size, then look through their bins to match length. Much better selection than H/D or Lowe's. also if you have a Fastenal near you they will have them. Smiley
allanbegg
Marietta, PA
« Reply #13 on: March 28, 2016, 06:34:48 PM »
And if you are willing to wait on the shipping, McMaster-Carr has every imaginable combination of material, length, size, and style of head.
However, you would need to know the dimensions first.
http://www.mcmaster.com/
Allan
VRCC # 36795
Gideon
Indianapolis, IN.
« Reply #14 on: March 29, 2016, 05:41:44 AM »
Indybobm is correct. The screws are 4mm X 12mm.
I used "Chrome" Allen Head Screws from ACE.
Also, do as Hukmut suggested.
Happy trails!
Steve K (IA)
Cedar Rapids, Iowa
« Reply #15 on: March 29, 2016, 09:12:09 AM »
The PO must have changed out those screws.  Mine on both Valks are Phillips head.  Like the idea of flat head socket though.
« Last Edit: March 29, 2016, 09:14:41 AM by Steve K (IA) » Logged
States I Have Ridden In
