February 11, 2026, 04:01:41 AM *
Author Topic: Choke cable  (Read 874 times)
pais
One more turn should do it!
Kent, Ohio
« on: October 20, 2015, 01:44:32 PM »
  Would someone please post a pic of there choke cable, showing it routed down to where it hooks up to carb bank, please. I took it out about 10 days ago so I could lube it and swore I'd remember how it went. Guess what I for got and did not take 1 pic. Your help will be appreciated. Thanks
Bone
« Reply #1 on: October 20, 2015, 04:28:09 PM »
Next time you pull a cable tie a string on the end. Pull the cable and the string follows.
Stop when the string appears and untie or cut the string.
Tie the string on the new cable and gently pull the cable with the string. The new cable
goes the exact route the old cable used.
« Reply #2 on: October 21, 2015, 03:13:18 AM »
Pais, the Honda manual has very good detailed cable route graphics.
Do a search for Dag's posted manual if you don't have a hard copy.
If I had time, I'd find it for you.
Maybe someone else will.
Good luck.
« Reply #3 on: October 21, 2015, 04:08:47 AM »
Dag's site with the download for the service manual follows:
http://www.valkyrienorway.com/download.html
My rides:
pais
Kent, Ohio
« Reply #4 on: October 22, 2015, 12:54:30 AM »
Good luck.
Salty, couldn't see the forest through the trees. I never gave a thought to checking manual. Never would of thought that info would be found their  uglystupid2
   Thanks for posting, I have it down loaded on my lap top. One of the first things I did when I joined the club. Now, I guess I better utilize it to its capabilities. Thanks again.
