February 11, 2026, 04:01:44 AM *
Author Topic: Source for Throttle Tube  (Read 1036 times)
BudMan
"Two's in."
Tecumseh OK
« on: October 22, 2015, 05:44:53 AM »
Does anyone know where I can get a Throttle Tube that has the threaded end still intact? I am putting stock grips on my Interstate and my current tube has it broken off.
Buddy
Tecumseh OK
MOOT# 263
VRCC # 30158
1948 EL Harley
2013 F6B Delux
« Reply #1 on: October 22, 2015, 07:32:40 AM »
I love OEM grips. They come with the throttle sleeve...
BudMan
"Two's in."
Tecumseh OK
« Reply #2 on: October 22, 2015, 07:50:10 AM »
Thanks  Mike, but I already have the grips from another endeavor. Just need the sleeve.
Buddy
Tecumseh OK
MOOT# 263
VRCC # 30158
1948 EL Harley
2013 F6B Delux
vanagon40
Greenwood, IN
« Reply #3 on: October 22, 2015, 11:16:04 AM »
The sleeve is not sold separate (unless you could find it used on ebay, etc.)  It comes with the OEM grip.  Part No. 53145-MM8-000.  Price at Partzilla is $26.49 plus shipping.  Partzilla cross references a lot of different bikes.
Might try a parts wanted in the classified.
[My 1,000th post]  Smiley
The Part Number is for a Standard, not sure if the Interstate is the same.
« Last Edit: October 22, 2015, 11:22:34 AM by vanagon40 » Logged
Jack B
Two Rivers Wis
« Reply #4 on: October 22, 2015, 11:24:18 AM »
 I have the same issue a back and had to order them from my Honda dealer and take the original grips off, it was a pain but there was  no other options.
Let’s RIDE
big poppa pump
San Antonio, TX
« Reply #5 on: October 22, 2015, 12:05:46 PM »
Here you go, I am using one of this on my yellow Valk without any issues.
http://xchoppers.com/product_info.php?products_id=2473
It was 2.95 around the same time last year. Price has almost tripled. BASTARDS!!!
« Last Edit: October 22, 2015, 12:08:42 PM by big poppa pump » Logged
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
Valkpilot
What does the data say?
Corinth, Texas
« Reply #6 on: October 22, 2015, 12:58:47 PM »
As noted above, you can't buy the OEM throttle tube by itself and aftermarket tubes don't have the threaded nipple on the end for the OEM end cap to screw onto.
So, I get these: http://www.jpcycles.com/product/ZZ50014
I like the look, better quality than Kuryakyn, less expensive than Kury and about the same price if you replaced both OEM grips, and come with a throttle tube.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
BudMan
"Two's in."
Tecumseh OK
« Reply #7 on: October 22, 2015, 12:59:45 PM »
Story of my life... Day late and a dollar short. crazy2
If it were raining soup I'd be outside with a plate and a fork. tickedoff
Just before seeing this last post I ordered a new right sleeve and grip from BikeBandit for $31.03.
I placed the order, and was coming back here to thank everyone and I saw a note that I may want to check the thread before posting...
Yep, that was  your post Poppa.
Thanks everybody!
Buddy
Tecumseh OK
MOOT# 263
VRCC # 30158
1948 EL Harley
2013 F6B Delux
