sid
« on: November 01, 2015, 07:11:40 AM » |
valk was driven from storage to gas station then to garage, ran fine, then two weeks later, will not run but 3 sec then quits. have pulled tank and install external fuel supply, have pulled gas feed off left bank,line to there not plugged, if I pour gas in carb intakes bike will run longer. any suggestions out there ??
« Reply #1 on: November 01, 2015, 07:17:56 AM » |
Valkyries can have big trouble with petcocks that need rebuilt... if it ran fine before, its probably mostly OK...
« Reply #2 on: November 01, 2015, 08:44:12 AM » |
I said the same thing when I talked with Sid this morning . He's feeding gas straight ( by-passing the petcock ) and it still will only run a few seconds .
« Reply #3 on: November 01, 2015, 10:04:29 AM » |
And how is it running for a few sec only? While on chock or?
I'm thinking electrical.
Have you checked the battery? Maybe add a jumper from a known good battery.
Other than that, a low spark maybe. When cranking, it will fire up only after there is a large build up of fuel, then after that burns off to a normal level, it dies. I've had this issue with cars before. More electronics. Don't know what there could be on the bike that would match it.
« Last Edit: November 01, 2015, 10:53:04 AM by gordonv »
« Reply #4 on: November 01, 2015, 10:13:00 AM » |
If you can get it running only a few seconds, be assured the problem is not electrical.
Try draining some gas from the bottom of each carburetor. The chances are the bowls are
crummed up and the possibility you have ran some of that crud up into the low speed
gallery is high. Hopefully a good strong dose of additive will clean up your problem, but that
will be only if you are attentive in how you approach and carry out the cure.
« Reply #5 on: November 01, 2015, 11:47:08 AM » |
Here's a suggestion when draining the carbs. Attach a MityVac to the drain hose that hangs out under the bike on the right side with a couple other hoses. Pump up the MV good and open one carb drain screw. By doing the above, it creates turbulence in the bowl and draws out more junk if in there. Close that drain screw and do the same with each of the six carbs. I agree with Ricky, most likely not electrical but if there's any junk present it most likely has been drawn into the metering system. When you fed it sans the tank, did you use the normal fuel line that attaches to the petcock? I'd first drain the carbs as described, then use the main feed from the petcock to your external feed. Don't use a fuel feed off one bank, it won't distribute evenly enough to the other side.
Mo Lee
« Reply #6 on: November 01, 2015, 02:29:52 PM » |
I'll be following this thread. I guess I misunderstood you on the phone, I thought it ran ok on an external tank. I still stand by a strong dose of seafoam for a few days, if not it may require a carb teardown.
sid
« Reply #7 on: November 01, 2015, 03:32:07 PM » |
update... I used a Ketchup squirt bottle to feed fuel directly into air intake tubes, got engine to run that way, held it about 3500 RPM till fuel ran out, did that 2X. now engine will idle under full choke with external fuel but will not go up in RPM. looks like power or high speed jets are clogged. running Sea Foam in idle mode. now to find the carb drains
« Reply #8 on: November 02, 2015, 09:09:57 AM » |
Yeah, you've gone ahead with your shortcuts and have probably caused yourself to be in
a heap of carburetor trouble. Now you want to use probably the weakest of all the additives
available. I foresee many more posts regarding this particular Valkyrie and expect it may
be way next year, if by then, this bike ever gets running in a proper fashion. Get some Berrymans
or Techron as a starter.
nogrey
Nampa, Idaho
« Reply #9 on: November 03, 2015, 02:14:02 PM » |
Not sure if this will help. I guess it is something to ponder. I rode for 4 days with another friend who was riding a carbureted gold wing. On our last stretch we stopped for gas. We left the station and his bike would run for awhile and then die. We got him home. We figured bad fuel somehow. Anyway, he drained the tank and refilled with some good fuel and symptoms haven't returned. Since you filled the tank and the problem began, do you think that might be a possibility? How long was your bike in storage? Another easy suggestion: Remove one of the fuel bowls. You can do this pretty easily with an offset screwdriver. Pick one of the bowls from the right side (low side of bike while on kickstand). When you get the bowl off, take a look at how much gunk is in there. If it's varnished up and comes out hard, you've probably got six others that are just as bad. If there's a fair amount of gunk, you're probably looking at cleaning the carbs. I've used seafoam for years. It's never done much for me when carbs were dirty. It's a great insurance for keeping them clean though. Berryman's is also good. None of them will clean out gunked up slow jets. It's really rare for high speed jets to clog. Especially all six. If they're clogged, you're for sure looking at disassembly and cleaning.
dancnman
« Reply #10 on: November 03, 2015, 02:14:21 PM » |
Sid, where are you located? I have had and trouble shot fuel problems on 5 or 6 Valkyries. There is no shortcut to gunked up carbs. Pull them off and clean them. Ask for help to do that. If you are close to Houston, I can help.
Reality is that thing which does not change simply because I choose to ignore it.
« Reply #11 on: November 03, 2015, 03:32:46 PM » |
B12 chemtool is much better to use then seafoam
dancnman
« Reply #12 on: November 04, 2015, 03:42:30 AM » |
Ditto on B12. Nothing better. Goes in everything I own.
sid
« Reply #13 on: November 04, 2015, 05:53:09 PM » |
thanks guys, so far i drained left bowls, started using straight gas to purge the heavy seafoam, now have it starting and running without choke, sounds like hell, speeds up and down with steady throttle, busy till Saturday, will drain right side then. stay tuned for report.
« Reply #14 on: November 05, 2015, 03:10:09 AM » |
up and down idle means vacuum leak. check the vacuum caps on the intake manifolds, known to go bad. then pair valve lines, last intake manifold O-rings if first two don't fix the idle.
hukmut
« Reply #15 on: November 05, 2015, 08:21:54 AM » |
If/when you take your carbs apart for cleaning, BE SURE to replace those float needles. Those little springs will have weakened through years of use. It is a must do. One of the best things that you can do to your bike to prevent hydrolock. IMHO. Berryman B-12 is a good strong carb cleaner that has been shown to be effective in cleaning gunked-up fuel system. Ride safe.
valkyriemc
NE Florida
« Reply #16 on: November 05, 2015, 05:13:34 PM » |
Real good advice.
Veteran USN '70-'76
