March 15, 2026, 12:07:16 AM *
Author Topic: LED Mirrors ?  (Read 2566 times)
wayngo333
Ormond Beach , Fl
« on: November 01, 2015, 04:29:11 PM »
I find myself having a little difficulty with rear viewing. I am considering some slightly taller LED turn signal mirrors. This would have me losing the factory turn signals that I am not fond of anyhow. Has anyone changed their signals and or mirrors? Pro's/Cons-advice welcome.
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #1 on: November 01, 2015, 05:30:40 PM »
What voltage are these mirrors as our turn blinkers are not 12v
« Reply #2 on: November 01, 2015, 05:41:33 PM »
Know what you mean about the OEM mirrors was looking at some led mirrors also. Not sure what needs to be done to wire them up. I think this week I will tackle the led turn signal issue. I have the SoCal front driving lights and running lights and the running lights will flash yellow for turns and would like them to work rather than only running lights. I will explore what its going to take to do this or even if its possible. I would not think it was going to be a problem,  just off the top of my head but will check and let you know.
wayngo333
Ormond Beach , Fl
« Reply #3 on: November 01, 2015, 05:42:23 PM »
Not sure. They are on the kuryakyn fitment page. Will require more research. Any voltage info you have would be great. I selected by model.
wayngo333
Ormond Beach , Fl
« Reply #4 on: November 01, 2015, 05:45:13 PM »
Thanks to both. I will watch for what you discover, and post anything I find out.
_Sheffjs_
Sarasota FL
« Reply #5 on: November 01, 2015, 07:12:21 PM »
Don't know if you remember Gill on the yellow black 1500 at the party Robert, he also has a fairly new wing.  For this situ he gave me two electronic relays that take in 3-8v and supply a open closed circuit that can break a 12v source for lights.  My problem is I want the SoCal set but I feel the michey tires should come first.   Not sure why SoCal does not have this as a plan to compensate for the voltage difference maybe should run it by them first just in case they know something we don't?
« Last Edit: November 01, 2015, 07:15:56 PM by Sheffjs » Logged
dans2014
« Reply #6 on: November 02, 2015, 06:03:39 AM »
 Cool I had a pair of 2003 Suzuki 800 Volusia mirrors in the garage and mounted them. Got them off ebay. They are a bit wider and look exactly like the Valk mirrors. Now I can see behind me as they are a bit wider with the stalks.
Dan's 2014 Valkyrie
GA VALK
« Reply #7 on: November 02, 2015, 02:16:41 PM »
The previous owner of my bike installed black powder coated mirrors from an Indian or Victory motorcycle.  Much better look and view, especially with the extenders
