February 12, 2026, 12:07:30 PM
Rear Wheel Dampers Needed
Topic: Rear Wheel Dampers Needed (Read 1325 times)
icemanisintexas
November 02, 2015, 02:03:08 AM »
Does anyone know if Gary (as posted in an older topic of this forum ) is still making his Wheel Dampers for the Valkyrie and if so how do I get in touch with him and how much would they cost ?
Gerry
Re: Rear Wheel Dampers Needed
November 02, 2015, 02:20:29 AM »
He passed away. You can get the ones for the Interstate models. They have the metal collar imbedded in them.
Thunderbolt
Worthington Springs FL.
November 03, 2015, 04:17:40 AM »
What Meathead said. Buy the part no. for the Interstate.
Bagger John - #3785
November 03, 2015, 06:01:47 AM »
Is Honda no longer offering them for the Std/Tourer models?
Thunderbolt
November 04, 2015, 03:42:12 AM »
Reason for recommending the Interstate models is that they have the aluminum drive rings molded inside and you don't have to buy them separate. They will all fit each model.
Bagger John - #3785
November 04, 2015, 06:35:43 AM »
Quote from: Thunderbolt on November 04, 2015, 03:42:12 AM
Noted.
Yet another thing for the Box O' Spares I've been gathering.
Reply #6 on:
September 27, 2016, 10:19:08 AM »
For future searches
http://www.partzilla.com/parts/search/Honda/Motorcycle/2000/GL1500CF+A/REAR+WHEEL/parts.html
06410-MBH-000
Last Edit: September 27, 2016, 10:27:21 AM by Britman
rhinor61
Northern California
Reply #7 on:
September 27, 2016, 11:53:14 AM »
06410-MBH-000
DAMPER SET, WHEEL
$30.55
http://www.procaliber.com/oemparts/partsearch/honda
John
Northern California
1998 Valkyrie Tourer Black/jade
VRCC #28001
Reply #8 on:
September 27, 2016, 12:14:44 PM »
Quote from: rhinor61 on September 27, 2016, 11:53:14 AM
06410-MBH-000
DAMPER SET, WHEEL
$30.55
That part number is just for the rubbers. Partzilla includes the metal insert as well.
Last Edit: September 27, 2016, 12:18:05 PM by Britman
Reply #9 on:
September 27, 2016, 05:04:36 PM »
Quote from: Britman on September 27, 2016, 12:14:44 PM
06410-MBH-000
DAMPER SET, WHEEL
$30.55
The metal insert is made inside the rubber Dampners. Look at the plate that holds them down mine was bad because of the metal rubbing on them after the rubber wore away from the metal.
Reply #10 on:
September 27, 2016, 05:43:14 PM »
Actually, the p/n given is the same for the I/S dampers with the metal inserts. Strange that the # is the same for just the rubbers if you look on a 2000 Tourer screen, the metal inserts are an extra $9.99. Anyway, just order item #1 off an I/S screen and you get the complete set.
