November 26, 2025, 07:57:18 PM *
Author Topic: Chrome, a little rust and steel wool  (Read 1563 times)
« on: November 02, 2015, 08:07:11 AM »
Was speaking to Lucky13 about chromers and he reminded me steel wool does a pretty good job at rust removal.
8 years and 137,000 miles of ST1300 riding and not much chrome to keep shiny.
Some vigorous hand application of 0000 grade steel wool and most of the rust has gone.
I then duct taped a pad of steel wool to my variable speed drill bit to get into the smaller curves that my digits couldn't and voila the rest of the rust is 99% gone.
« Last Edit: November 02, 2015, 08:09:57 AM by Britman » Logged
Bagger John - #3785
« Reply #1 on: November 02, 2015, 08:36:04 AM »
This stuff works pretty good too:
http://www.collinite.com/marine-wax/liquid-metal-wax/
Use it sparingly, and by hand application only if at all possible. Remember it's a mild abrasive, just like the steel wool.
I take a half-empty tin of Mother's Carnauba Wax and mix an equal amount of #850 in, then use the resultant slurry on my wheels. Clean and polish while wet; allow to dry then buff off. One or two applications per season are all that's needed and the wheels shine brightly afterward.
« Reply #2 on: November 02, 2015, 10:05:38 AM »
If coated wouldn't that remove the caoting?
« Reply #3 on: November 02, 2015, 10:19:48 AM »
Thanks.
Amazon Prime will have it to my door on Wednesday - free shipping!
Bagger John - #3785
« Reply #4 on: November 02, 2015, 10:39:34 AM »
Yes - that's the only gotcha. Don't use on clear-coated surfaces.
You owners of 2001-2003 Standards have it lucky where the wheels are concerned...just a little wash and wipe is all that's required to keep them clean. Contrast that to my second I/S - 19h total over a two-day weekend to clean and polish the wheels, starting with 150gr wet emery cloth and progressing to finer grits as the oxidation and pitting was removed. 2000gr crocus cloth and Collinite/Hagerty's/Wenol polishes finished out the exercise. I don't think the original owner ever cleaned them.
What a PITA.  tickedoff
Pete
« Reply #5 on: November 02, 2015, 01:19:12 PM »
With steel (0000) wool I always use a cheap cleaner/wax as an lube assist and to help prerserve the shine.
With just steel wool it can dull the chrome and with out the wax it just rust quicker.
« Reply #6 on: November 02, 2015, 01:27:57 PM »
I put a little chrome polish, thanks. Should have mentioned that.
Thunderbolt
Worthington Springs FL.
« Reply #7 on: November 03, 2015, 03:54:43 AM »
Gordon gave you some good advice on the 0000 steel wool.  I get the soap impregnated pads from the local discount store like Dollar General or Big Lots.  They have a slick soap in them and they work really well.  Of course when that is done they will need to be waxed well.
Pappy!
Central Florida - Eustis
« Reply #8 on: November 04, 2015, 06:12:13 AM »
That is the way I do my aluminum boats that I leave in a factory style finish (not mirror finish) and it takes oxidation right off.
Initially you will feel resistance and then it gets super smooth feeling. At that point you can move on to another section.
« Reply #9 on: November 09, 2015, 01:26:58 PM »
Aluminum foil for removing rust!
http://www.robertscycle.com/chrome-clean.html
« Reply #10 on: November 09, 2015, 05:23:17 PM »
White Diamond.   cooldude
indybobm
Franklin, Indiana VRCC # 5258
« Reply #11 on: November 09, 2015, 06:19:59 PM »
I use 0000 steel wool also but I spray it with WD40 first.  I do the same thing with scotch bright pads.
So many roads, so little time
VRCC # 5258
Paladin528
« Reply #12 on: November 17, 2015, 11:16:03 AM »
Use Aluminium foil on aluminium surfaces and Steel wool on steel or chrome.  this will help avoid Galvanic corrosion due to the dissimilar metals.
Crhii
Midland, Texas
« Reply #13 on: November 25, 2015, 10:53:46 AM »
I know that I am a little late responding, but polishing on chrome is best done with brass wool. It doesn't scratch the chrome.
« Reply #14 on: November 25, 2015, 11:28:27 AM »
Where can one get brass wool?
« Last Edit: November 25, 2015, 11:30:28 AM by Britman » Logged
Steel cowboy
Spring Hill, Fl.
« Reply #15 on: November 25, 2015, 11:44:21 AM »
Marine suppliers
2001 black interstate
2003 Jupiter Orange wing
