« on: November 03, 2015, 12:13:42 PM » |
« Reply #1 on: November 03, 2015, 12:16:11 PM » |
Sure
« Reply #2 on: November 03, 2015, 12:18:22 PM » |
I can't speak to that brand, but Yuasa uses the same YTX14-BS number for the battery they supply for the Valkyrie.
« Reply #3 on: November 03, 2015, 12:38:37 PM » |
dancnman
« Reply #4 on: November 03, 2015, 02:06:13 PM » |
I just bought the same battery for my Interstate. I am totally happy with it and it is about 60.00 less than I have been paying for name brand batteries that only last a couple of years. Seems to be good construction too. Go to their website and save a couple of more dollars.
Reality is that thing which does not change simply because I choose to ignore it.
« Reply #5 on: November 04, 2015, 09:41:39 AM » |
Thanks and free shipping too!
grepper
« Reply #6 on: November 05, 2015, 10:32:10 AM » |
This is the one I just got: http://www.batterystuff.com/powersports-batteries/YTX14H-BS.html Note the 240 cranking amps, plus it's a rebranded Yuasa. I get all my motorcycle batteries for batterystuff, good prices and great quality.
New to Valkyries and Big Bikes in general. Other Bikes: 1978 xs650 Standard, 1979 XS650 Bobber, 1975 CB750 K5 (Wife's Bike), 1979 & 1981 CB750K (basket Cases), plus a Whahoo Scooter (Cheap Chinese thing I got for free).
« Reply #7 on: November 05, 2015, 11:19:08 AM » |
If you didn't see this Warning: Do not use a battery charger with a desulfation mode and/or a peak voltage exceeding 14.8 Volt. We recommend only using the DelTran Battery Tender Junior Lithium PN: 022-0198Li
Paladin528
« Reply #8 on: November 05, 2015, 11:21:10 AM » |
yes using a standard charger will cause the battery to thermal runaway and burn you bike to the ground. Very bad
« Reply #9 on: November 05, 2015, 11:49:25 AM » |
Looking at the two Yuasas for our bikes, the regular and the extra CCA, I seem to recall someone posting that the extra CCA battery actually has less or smaller cells, thus it would put out more amps, but it's projected longevity was almost certainly shorter than the standard. I only get the standard Yuasas, and on 24 X 7 B-Tender Jrs, they last for many years.
I have a few extra plugins, but nothing drastic, draw wise. And I am careful not to run them all together.
« Reply #10 on: November 05, 2015, 12:15:24 PM » |
After my recent house fire I Googled battery charger fires and most I saw resulted using the wrong type of charger with a Lithium battery especially RC battery [packs. Some took only 30 minutes to rupture in flames.
« Reply #11 on: November 05, 2015, 05:16:18 PM » |
If you didn't see this Warning: Do not use a battery charger with a desulfation mode and/or a peak voltage exceeding 14.8 Volt. We recommend only using the DelTran Battery Tender Junior Lithium PN: 022-0198Li very aware, only a standard battery charger can be used, which I use.
