February 11, 2026, 09:55:55 AM
Speedometer Issues
Topic: Speedometer Issues (Read 938 times)
Bond
Clive Iowa
Speedometer Issues
November 04, 2015, 03:21:15 PM »
I have a 99 Interstate
My speedometer stopped a few months ago, after reading several post I figured I need to replace my sensor but kept putting off spending the money then few weeks ago it started working sporadically. some rides it works fine, some off and on and some not at all. When it does start working the radio volume gets louder. I am thinking a ground somewhere? Any clues? I don't relish taking my ferring apart to trace wires. Anyone already tackle this have any clues
Re: Speedometer Issues
November 04, 2015, 03:28:39 PM »
There is a box on the lower left fork that has a small bolt that holds it on. See if that bolt is snug. It's a Phillips head. SNUG NOT hammered tight! RIDE SAFE.
Michvalk
Remus, Mi
November 04, 2015, 04:31:55 PM »
The speed sensor for the speedo controls the automatic volume control for the radio. If the speedo isn't working, the volume stays steady, at the set level. When the sensor starts working, the radio turns up the volume, to that set level. Replace the sensor!
BigMac (SoCal)
Moreno Valley, California
November 04, 2015, 07:50:48 PM »
Take the sender at the wheel apart and clean the pick up. Mine went out on the way home from InZane in June and that's all it took to fix it
Dave
nerider2
Omaha, NE
November 06, 2015, 12:26:01 PM »
I had the same problem, I just bought one on eBay and replaced it. It has worked fine since.
2014 Daytona Blue Ultra Limited
2000 Stealth Interstate
1999 Excelsior-Henderson
Omaha, NE
VRCC #23874
Iron Butt Association #32532
Bond
Clive Iowa
December 16, 2015, 12:08:49 PM »
Thanks for all the advice. I took the sensor off and took it apart, found the little wheel inside was hanging up and not turning freely. sprayed some cleaner on it followed by some good old WD40 which freed the wheel. Took it for a ride today and froze my butt off but the speedo works fine.
msb
Agassiz, BC Canada
Reply #6 on:
December 16, 2015, 01:05:38 PM »
Quote from: BigMac (SoCal) on November 04, 2015, 07:50:48 PM
Dave
Must have been something in that SD weather...mine cut out on the way home from Inzane as well - first time in 15 years. Cleaned it up and it's worked fine since.
'99 Red & Black IS
