February 11, 2026, 07:41:30 AM *
Author Topic: De-Smog: What else should I do?  (Read 903 times)
Fazer
« on: November 13, 2015, 06:15:21 AM »
Going to tackle the standard de-smog this weekend (98 Tourer).
While I am at it and have the air box off I am installing a Dan-Mark electric shut off, replacing the vacuum line to the petcock, and I have a petcock re-build kit.
I also have new O-rings for the intakes--is it easier getting the airbox back together with the intakes removed?
Just took delivery of a lift adapter that I can install prior to any of the above mods.  For those of you that have already de-smogged, is the process aided by raising the bike, or is it best to leave it on the kick stand?
Anything else I should do during this process.  I am also replacing the air filter.  20,000 miles on the clock and I have no idea if the AF has ever been out.  It had 17000 when I got it.
I'll try and take some photos, but I know there has been tons of stuff posted about everything I am doing.
greg
Nothing in moderation...
« Reply #1 on: November 13, 2015, 06:33:13 AM »
I didn't have mine raised when I did the desmog. I don't see any reason to. I think you will need the intakes on to install the air box. For me using a ratchet strap and small block over the air box really helped. I don't remember who posted that trick but you can find it in a search. Take your time and you'll be fine. Are you using a desmog kit or doing it old school ?
« Reply #2 on: November 13, 2015, 06:55:08 AM »
I raised mine just because it's a bit easier if you don't have to bend over so much.  My back appreciates that. I didn't need a desmog kit on either bike.  You can close off the pare lines by folding them over and crimping them with a vise-grips.  Except for #1 which is harder to reach.  Plug that one with JB Weld on a piece of a bolt - forgot the size. Close off the nipples by putting silicon glue inside a piece of the vacuum line.  Easier to put the airbox back in if you use a ruler or the like to push the carb inlets over while lowering the airbox. I made my petcock strictly manual with the mod recommended by the belly tank folks.  I can scan and post it here if needed. No more vacuum lines.
« Last Edit: November 13, 2015, 06:57:29 AM by MarkT » Logged
Fazer
« Reply #3 on: November 13, 2015, 07:12:32 AM »
Thanks for the replies.  I was going to do the de-smog as shown on shop talk (I think) page--not using a kit.  I have bought 14mm freeze plugs, made the alum blank plates and purchased new fuel line/vacuum line/brass fittings for the fuel valve.
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #4 on: November 13, 2015, 07:33:00 AM »
Raise that baby up if you can it is much easier to work on that way
« Reply #5 on: November 13, 2015, 07:42:43 AM »
Sounds like you have it under control  cooldude
Can't argue with that logic. Especially someone who has worked on as many as you have.  cooldude
Steel cowboy
Spring Hill, Fl.
« Reply #6 on: November 13, 2015, 05:19:36 PM »
Why de-smog does it improve gas mileage, engine performance.
2001 black interstate
2003 Jupiter Orange wing
« Reply #7 on: November 13, 2015, 05:26:35 PM »
Nope.  It eliminates a maintenance issue.  And if your vacuum lines are already leaking - well it takes care of that now and forever.
