November 26, 2025, 04:47:47 PM
Interstate rear speaker
Topic: Interstate rear speaker (Read 2486 times)
jdp
November 19, 2015, 06:49:15 AM »
Well here I am again, seems like I'll never get this bike on the road, a lot of little issues I'm trying to iron out and thanks for all the help, like I said before this is the bike of my dreams and I would like to get it right, on my interstate there are no rear speakers, I've found the plug in the harness and would like to plug and play so I dont have to cut into the harness, I've found a lot of harness for the old gold wings but will they fit on the Valkyrie ?thanks again for the help
Bagger John - #3785
Re: Interstate rear speaker
November 19, 2015, 08:13:49 AM »
Here ya go:
http://www.bigbikeparts.com/templates/product.aspx?ProductGuid=2-169C&GroupGuid=906
You can get the Hitachi connector (which mates with the rear speaker output plug on the stock Valkyrie harness) from Electrical Connection. A GL1xxx harness could be modified or you can construct one from scratch - it's not that difficult.
jdp
November 19, 2015, 01:21:25 PM »
The harness kit for a gl1500 gold wing will the s work for a Valkyrie?
mark81
Cincinnati Ohio
November 19, 2015, 05:19:45 PM »
I just added rear speakers to my interstate. I used the wiring that came with the speakers. routed into the lower trunk at the hinges( there is a small gap there where the inner and outer shell meet) and out the bottom with the brake light wiring. I was lucky when I went to the local Honda shop they were able to find a connector and cut it off a scrap harness. most of the 4 wire connectors Honda uses on everything are interchangeable. the one I used came off the handle bar controls from a mangled up quad. only difference is the color of the plastic
1997 Honda Valkyrie
1981 Honda CB750 Custom
November 19, 2015, 06:02:02 PM »
I bought a pre made harness for mine about three years ago but cursed if I can remember where from someone here put me on it so someone may chime in with the guy who makes them.
Mr Whiskey
November 20, 2015, 02:34:49 AM »
Call Lewis, he'll have what ya need.
http://www.electricalconnection.com/
Peace, Whiskey.
dieselforce
Grandville, MI
Reply #6 on:
November 20, 2015, 05:01:39 AM »
Where does the wire harness connect to? Under the seat by the accessory plugs or up in the fairing by the radio?
cialispascherfr24 pharmacy
Bagger John - #3785
Reply #7 on:
November 20, 2015, 05:13:45 AM »
Quote from: dieselforce on November 20, 2015, 05:01:39 AM
Right side cover comes off and you'll find the plug in there, enclosed in a plastic boot.
=> InZane XXV
