April 29, 2026, 08:44:11 PM *
Pages: 1 [2]   Go Down
Author Topic: The Adventures in Valkyrie Wiring!  (Read 13764 times)
Moofner
Colorado Springs, CO
« Reply #40 on: March 28, 2016, 11:32:20 AM »
I'll check that, thanks !  cooldude
Depending on your Givi trunk, I could point you in the right direction for a light kit in that trunk. I'm quite happy with mine.
2003 Valkyrie "Ricky's Bike"
2014 Valkyrie "The Gypsy Bride"
ledany
Paris, FRANCE
« Reply #41 on: March 28, 2016, 01:44:44 PM »
Thanks for the proposal but considering the fact that I'm not able to find the plug behind the horn, I will decline !  Embarrassed
I did try today, couldn't find it, even though I read this
http://powersports.honda.com/documentum/MW01/08V70-MJR-670.pdf
dinosnake
« Reply #42 on: March 28, 2016, 04:42:14 PM »
Forget trying to use those instructions to help you find the connector, it is of absolutely no help.
Your best chance is to look at the wiring diagram, such as
http://cdn1.bikebandit-images.com/schematics/schematics/honda/hon019/hm0614028071.gif
The fog light connector is down in the lower right, see fittings #21 or #22 (can't remember which).  Find that branch of the harness and follow it until you reach the terminations, this is how I had to find the connector on my bike.
« Last Edit: March 28, 2016, 04:58:24 PM by dinosnake » Logged
Moofner
« Reply #43 on: March 28, 2016, 07:20:01 PM »
These will be the LEDs I use for my turn signal idea. If the prototype harness lights these bad buys it will light anything we can think of.
mikesgotmods
« Reply #44 on: March 29, 2016, 06:05:43 PM »
Hey Moofner, awesome work so far!! Do you think the next time you speak with the folks at Admorelights you could inquire about making our rear turn signals also function as running lights just as our fronts do?
Moofner
« Reply #45 on: March 29, 2016, 06:36:42 PM »
The first place to start would be to find out if the front and rear turn signals are the same part number. Usually, running light LEDs are 5 volt and the actual bright signal flashes on when it gets 12 volts. As far as I can tell, this system is different and uses a pulse for signal. The lights are always getting 12 volts!
I'm not sure they can be turned into running lights even with an adapter. I'd love to see if anyone has got them to work. I did see someone that got a new fender eliminator kit to work, but it was a tail light with amber signals as well.
mikesgotmods
« Reply #46 on: March 29, 2016, 07:04:25 PM »
I just checked the part numbers and each turn signal has a different part number, but just by looking at the signals, it looks like fronts would bolt up to the back. Mabie that's a starting point.
Moofner
« Reply #47 on: March 30, 2016, 10:14:20 AM »
So I did a lil experimenting and I'm digging the results. This will now be the new turn signal setup I test Admore's prototype harness on. Straight 12 volts lights'em up! I'm also pre-wiring the bike so I can install a couple amber stripes on my skid plate. It will be a nice effect to light up the road, either left or right,  depending on which way I want to turn.
Time to start doing the final wiring and putting it all back together! Only 3 weeks before I'm off to Daytona!
Opinions?
goldstar903
« Reply #48 on: March 30, 2016, 05:36:23 PM »
Opinions?
You might want to step it up! Instead of Daytona, you might want to consider Canaveral?
Their having a launch on Target Date: April 8, 2016 - 4:43 p.m. Eastern
Mission: SpaceX CRS-8 Resupply Mission to International Space Station
Description: The Dragon capsule will launch a 2014 Honda Valkyrie F6C, piloted by Captain Moofner from Space Launch Complex 40 at Cape Canaveral Air Force Station (CCAFS) in Florida, carrying science research, crew supplies and hardware to the orbiting laboratory in support of the Expedition 47 and 48 crews.
« Last Edit: March 30, 2016, 05:38:33 PM by goldstar903 » Logged
I love to go fast, but my wallet doesn't! Maybe I should leave my wallet home!
bscrive
Ottawa, Ontario
« Reply #49 on: March 30, 2016, 05:57:46 PM »
It will be interesting to see if the LEDs hold up to the heat from the rads.  If you have no problems in Florida then I may do the same thing.   coolsmiley
Moofner
« Reply #50 on: March 30, 2016, 08:19:29 PM »
I'm not gonna lie... I was so excited for this idea that I didn't even think of the radiator heat. I did check out the high range on led strip lighting and it was 60 degrees Celsius.... So that's 140 Fahrenheit. I might be in trouble!  Undecided
Moofner
« Reply #51 on: March 31, 2016, 09:40:27 PM »
Tonight's ongoing wiring adventure involved lighting up the battery and storage door access "Valkyrie" panels and installing my stainless skid plate with reinforced silicone LEDs for some ground effects.
That skid plate was annoying to line up, but I got it. I placed the LEDs away from the exhaust pipes but also not too far in the center. They have a nice gap of air around them so they shouldn't overheat, and their silicone sleeves will help them against excessive heat buildup.
Little victories are adding up and the bike is starting to look like I imagined it would. Anyone that hits me at night will be committing first degree... there is no way I won't catch a cager's attention.
A different color for tonight's progress report!
goldstar903
« Reply #52 on: March 31, 2016, 11:43:32 PM »
The space station couldn't hit you!  angel
dinosnake
« Reply #53 on: April 01, 2016, 03:05:36 PM »
So pretty!  But I'm too tired and lazy to do all that work any more  laugh
Moofner
« Reply #54 on: April 03, 2016, 08:31:22 PM »
Ugh, you are correct! You cannot be lazy in this kind of love/hate relationship.
SHE IS DONE! First stage is complete. The bike is put back together. The turn signals are pre-wired and awaiting Admore's controller. This was a nice project, but I'm glad she is back together so I can ride. I'm not lucky enough to have 2 motorcycles, yet!
I'm currently uploading a video on Youtube for a better example of the lights. I'll post the link once it is up.
Moofner
« Reply #55 on: April 03, 2016, 09:14:09 PM »
Here are the lights in action!
https://youtu.be/P38Pojcsuzc
Moofner
« Reply #56 on: April 13, 2016, 11:30:51 AM »
Alrighty then.
Admore sent me the prototype harness, and this is what it looks like installed (piggybacked off of the same connectors from my first Admore harness) on the bike. I did not install the red wire as that is for  a brake signal. This means you could use this harness for rear aftermarket signals and the turn signals can function as brake/tail lights.
The harness applies 5 volts to the lights as well as 12 volt turn signals, so this might work out for some people depending on the aftermarket lights purchased. I'm uploading some videos of the lights in action as I type this.
Moofner
« Reply #57 on: April 14, 2016, 10:04:14 AM »
I posted these videos to my Admore Lighting thread, but I'm also going to include them here since this is part of the overall bike build.
These are Youtube videos of the lights in action. You also hear my annoying voice. Mute as needed.
https://youtu.be/AdwG6BUPBTM
https://youtu.be/rk3U5Wdrq9g
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #58 on: April 14, 2016, 07:52:26 PM »
The Moof is loose - the Moof is loose.......................
I would love if it works with the SoCal lights. I'm guessing that it will however the amber turn light would be on all the time at present?  Might not be bad.   uglystupid2
Moof correct me if I am not understanding this.
Moofner
« Reply #59 on: April 14, 2016, 09:00:07 PM »
To be honest... I don't know. It depends on the SoCal lights. If they require 12 volts or more to switch over from the driving white lights you are good to go. If they switch when sensing ANY voltage, you will always have yellows. I just don't know without having a set of SoCal lights myself to test. I had Admore make a UNIVERSAL harness, and that has opened up a world of possibilities based upon the individual manufactures of aftermarket lights. I've asked them to make a harness that does 12 volts only. They are going to look at their stock on hand and see what they can do. They are very interested in my ideas and bike, as no one has been in this much contact with them (so they say).
The funny part about all this is that we haven't just made a harness for just our new style Valkyries, we have made a harness for ALL bikes EVER! The kit will sense traditional 12 volt incandescent wires as well as new style LED pulse modulation. I have literally helped Admore create a universal bike harness.
Moofner
« Reply #60 on: April 14, 2016, 09:18:15 PM »
Stanc,
I've sent an email off to SoCal telling them what I've done. I can figure this all out pretty quick if they let me test out a set of their lights.
A long shot for a good answer, but it is the best I can do.
Moofner
« Reply #61 on: April 14, 2016, 09:26:10 PM »
I think it is time to put an end to this chapter of my wiring journey. Here is the latest results.
It might not be much, but I think I've done a lot for this bike. I've enjoyed the challenge and I know I'm bring something special to my night time riding. Thanks to everyone that has enjoyed the adventure with me. Now if you'll excuse me, I have to go to bed. I have to be the Master of Ceremonies for Eglin Air Force Base's Annual Motorcycle Safety Day tomorrow.
That is right folks, not only does Moofner make bikes look cool, he does speeches in front of hundreds of people too. Motorcycle riding safety is important to me. Everyone should get home safe on two wheels. Also, never trust anyone that refers to themselves in the third person. They are nuts!
havoc
VRCC #36861
Calgary, Alberta CA
« Reply #62 on: April 15, 2016, 08:40:24 AM »
totally flippin' awesome man! thanks for posting Moofner
"Not all those who wander are lost" - J. R. R. Tolkien
Pages: 1 [2]   Go Up
