February 11, 2026, 09:55:58 AM *
Author Topic: Valve or exhaust noise  (Read 1174 times)
jdp
« on: November 30, 2015, 07:20:35 PM »
Has anyone had an exhaust leak sound like a valve tap?and has anyone tried those new style header seals? I think they look to be made flat instead of the round copper ones.
Blackduck
West Australia
« Reply #1 on: December 01, 2015, 03:02:25 AM »
Yes, the can sound like a tap or knock, retighten the flange nuts.
« Reply #2 on: December 01, 2015, 07:18:22 AM »
Yep, first thing is to try and 'snug' them up. Go easy with them.
These exhaust leaks can be a real PITA to stop at times. I like the fiber gaskets.
WintrSol
Florissant, MO
« Reply #3 on: December 01, 2015, 07:46:47 AM »
When I replaced a valve, I used the 'new' style gaskets, and they sealed just fine.
O-B-1
Vancouver, WA
« Reply #4 on: December 02, 2015, 05:52:41 PM »
Make sure any PO (previous owner) or service tech didn't leave old crushed gaskets in place and put new ones in on top... Found that on mine. Peeled all the old copper "crushed" gaskets out, replaced with a single new one in each port and fixed that.
Also know that a ticking noise can be the reed valves in the PAIR exhaust air induction system ticking in their cans. I think I am desmogging mine soon, they are getting noisy on mine. I even checked the valve lash to make sure it wasn't that. Verified the sound was coming from up under the carbs.
David W. Mitchell
1999 Honda Valkyrie GL1500C
jdp
« Reply #5 on: December 06, 2015, 03:08:19 PM »
Just wanted to let everyone know it was the exhaust donuts, I replaced the ones on the Side that was tapping and no more noise,thanks, man the way it was tapping sure sounded like a bad valve.
