February 11, 2026, 09:56:50 AM *
Author Topic: How to winterize your Motorcycle.  (Read 3978 times)
nogrey
Nampa, Idaho
« on: December 01, 2015, 05:09:46 PM »
I read this article on the "Wings Forum". I take no credit for it, but I thought it was a good article and worth a share. Thanks and credits to the Goldwing Forum.
There are some important tasks you need to perform when putting your bike away at the end of the riding season. The list here is what I perform on all of my bikes at the end of the season, and is a mixture of Honda-recommended procedures and my own. First, this is what Honda recommends you do in order to store your bike:
Change the engine oil and filter.
Make sure the cooling system is filled with a 50/50% antifreeze solution.
Fill the fuel tank. Make sure the fuel fill cap is properly installed.
Drain the carburetors into an approved gasoline container. If storage will last longer than one month, carburetor draining is important, to assure proper performance after storage.
With the engine stop switch in the OFF position, press the start button several times to crank the engine and distribute the oil.
Remove the battery. Store it in an area protected from freezing temperatures and direct sunlight. Check the electrolyte level and slow charge the battery once a month.
Wash and dry your motorcycle. Wax all painted surfaces. Apply rust-inhibiting oil to the chrome pieces.
Inflate the tires to their recommended pressures.
Store your motorcycle in an unheated area, free of dampness, away from sunlight, with a minimum of daily temperature variation.
Place your motorcycle on blocks to lift both tires off the floor.
Cover your motorcycle with a porous material. Avoid using plastic or similar non-breathing, coated materials that restrict air flow and allow heat and moisture to accumulate.
Now, my own procedures, some of which are slightly modified. I should mention that my motorcycles spend the winter in an unheated garage, with minimal exposure to the outside.
First on the list, I go for a decent ride - at least a half an hour, and preferably highway speed. This isn't (just) for fun - I want the engine and exhaust system as close to top operating temperature as possible. This lets the oil drain easily, and prevents moisture inside the exhaust (more on this later).
Next, I fill the fuel tank. Before doing this, I will go out for a ride and use up as much fuel as possible - I want no more than 1/4 tank of gas. I then add two items: first, half a can of Seafoam. This is normally used to clean shellac and deposits from the carburetors. In this case, I want it sitting IN the carburetors over the winter, to prevent the deposits from forming in the first place. Second, I add a double dose of Marine Sta-Bil fuel stabilizer. Why a double dose, and why the Marine version? First, this stabilizer is used to prevent phase separation - and you cannot do damage by overdosing your fuel. In fact, they tell you to use more when storing for longer periods of time. Second, the marine version of the product is designed for use where there is high humidity and frequent water incursion. It is far better at holding moisture in the fuel in suspension than the regular "red" Sta-Bil. Think of it as regular "red" Sta-Bil on steroids. In addition, the Marine Sta-Bil off-gasses a vapor that coats the inside of your fuel tank that is NOT submerged in gas, preventing corrosion. Once I've added both of these products, I fill the tank to the very, very top with FRESH, quality fuel, leaving as little air space as possible in the tank. Air in the tank = water vapor, so get rid of it as best you can. Lastly, I ride the bike for 5 minutes or so to make sure the fuel with additives has made it fully through the carburetors.
Adding Marine Sta-Bil to tank
I don't drain the carburetors. Especially on the GL1500 (and also on my wife's PC800) draining the carbs is an onerous and painful job. If I was going to be storing the bike for 6 months or so, I would very likely drain the carbs. However, when I am storing the bike for four months over the winter, and the carbs are full of a stew of Seafoam and Sta-Bil, they do just fine, and having used this method now for many years, it has never failed me. If your bike has a manual petcock, make sure to turn it off! If you do have a manual petcock, you can turn it off while the bike is running, and just wait until the engine dies. This ensures your carburetors have been drained of fuel. I use this method on things that are run very infrequently, like my generator.
Change the engine oil and filter. This is a given. Engine oil accumulates acids during normal engine operation, and left sitting, this will corrode the inside of your engine. Your engine will last many more years if you simply change the engine oil and filter before storing it each winter. For a more detailed explanation of why engine oil must be changed before storage, read this post. The Honda instructions say to crank the engine with the stop switch set to OFF after an oil change, to distribute the fresh oil. This is a good idea, and works on most Wings - except later model GL1500's and GL1800's, which will refuse to crank if the stop switch is OFF. My 2000 GL1500 is one of those bikes, so I instead start it briefly (10 seconds or so) to ensure the oil is fully distributed throughout the engine.
Check the coolant. I use Hondaline 50/50 premix coolant, so I know it's always the correct ratio, and it won't freeze. I also change the coolant every two years, so I know it's not worn out. I check the coolant level regularly, but this is a good time as any to check that your coolant isn't low.
Clean the fork tubes, and apply a light coating of oil. Pump the front shocks up and down a few times (sit on the bike, push the bike forward, then pull the front brakes while pushing down on the handlebars) to get the oil spread on the seals. This both helps keeps seals lubricated, as well as prevents corrosion on the fork tubes.
Check and fill the tires. You do not want your tires low over the winter - and in fact, it's a good idea to do this several times while it is in storage.
Checking and filling tires
Battery: I don't remove my battery. Why? Because I have a Battery Tender Jr. installed. I actually plug my bike into the Battery Tender every time it is parked - and in doing so, I went from replacing batteries once every 18 months to...well, I'm not sure, because I've been doing it for five years now, and in the five years since I installed Battery Tenders on all my bikes (and generators, and snowblowers, etc.) I haven't had to replace a single battery. People, seriously, get a Battery Tender, it will pay for itself many times over in extended battery life. As long as your battery is fully charged, the electrolyte will not freeze until near -40 degrees. On the other hand, a discharged battery can freeze at very close to 32F/0C, and a frozen battery is extremely dangerous! Put a Battery Tender on your bike, leave it plugged in, and you don't need to worry about pulling the battery from the bike. Those of you who store your bikes somewhere where electricity is not available, they now offer a solar-powered Battery Tender that will keep your battery in top shape with sunlight alone.
Wash and dry your bike. Really? Washing it? Actually, yes. Bug guts, road tar and general grime contain acids that will dissolve the protective coating on your paint - and your paint itself. Eventually the paint will just look bad. But I don't get out the hose for this job. I use the greatest invention motorcycling man has ever devised: Pro Honda Spray Cleaner and Polish. This stuff is so good, that virtually all bike shops use it. It makes cleaning your bike a non-event. I even use it on my car. Spray it on, wait a few minutes, wipe off with a clean towel, you're done. The result is an immaculately clean surface, with a protective coating left behind that will bead up water. You can use it on painted surfaces, plastic, windshields, chrome, aluminum, every surface on your bike. For chrome and steel parts, it leaves behind a coating that prevents corrosion from humidity over the storage period.
Lift your bike so it is not resting on the tires. Well...again, perhaps if I was storing my bike for six months or longer I might do this. Instead I simply put the bike on its center stand. This leaves maybe 40-50 pounds of weight on the front tire, which is really nothing, comparably. If you're really worried, you can put a wooden block under the engine block to lift the front wheel up off the ground. Keep in mind this will make the bike a bit less stable. Another alternative is to go in every couple of weeks, have someone push down on the rear of the bike to lift the front wheel in the air, then rotate the front wheel to prevent the same part of the wheel from resting on the ground. What we're really trying to do here is prevent flat spots from forming.
Cover the bike with a porous material - I don't bother. If my bike was outside, then yes, 100% I would be covering it up. But inside my garage, where the temperature remains fairly constant, there is very little dust, and there is little moisture intrusion, I leave it out in the open. More important is having an environment with a more or less constant temperature. If you are storing your bike outdoors, you should be using a cover that covers up as much of the bike as possible, is waterproof, but breathable. Do not use a tarp! This allows moisture to collect underneath, and will cause rapid corrosion.
Mufflers - mufflers rust from the inside out. They depend on the heat of the exhaust to evaporate moisture, so it is imperative that the bike was not just run for a few minutes and then shut down - this leaves moisture inside the exhaust, where it will sit and rust away while the bike is stored. This is the main reason we want the last ride before storage to be a long, fast one where the engine is working hard. We want things to be hot! Once things have cooled off, I spray WD-40 into the ends of the exhaust pipes (WD = Water Dispersal), then cover the ends of the pipes with a plastic shopping bag and a rubber band. This prevents the intrusion of moisture into the exhaust system.
Hydraulic fluids: If you haven't flushed/replaced your brake and clutch fluids in the past couple of years, this would be a good time to do them. These fluids are hygroscopic, which means they leach moisture out of the air - and moisture means corrosion. I typically do this every other year as part of my winter maintenance, so I don't normally do this at the time when I put my bikes away for the season.
Mice: Mice and other vermin LOVE motorcycles. They have lots of little cavities in which they can build nests, and they just LOVE to chew on electrical wiring. The air box in particular makes a perfect home for them. I put galvanized steel mesh over my air intake to keep the critters out. I keep mousetraps baited with peanut butter around the area the bikes are stored (they love peanut butter more than they love wiring), and putting Bounce brand dryer sheets in and around the bike helps keep them out. For some reason, they detest the smell of Bounce dryer sheets.
Now, what do you do now that the bike is away for its winter slumber? Please, please, PLEASE resist the temptation to "start it up to keep the oil fresh" or whatever other reason you feel you need to regularly run the engine. Your engine does not benefit in any way from being started from dead cold for a short "warm-up." In fact, it's quite the opposite. Starting the engine puts lots of moisture into both the crankcase and the exhaust. If you are not going to go out for a good, hard half hour ride, neither the engine nor the exhaust are going to get up to full normal operating temperature - which means this moisture is not going to evaporate. Instead, it's going to sit in the bike and start corroding the insides of your engine, cylinders and exhaust system. Every time you start it, it is making it worse. The fact that it is cold outside makes it even worse - this means the moisture easily condenses on the cold surfaces, starting the rusting process.
"But I need to start it regularly to charge the battery." No you don't, hook up a $25 Battery Tender instead of ruining your $500 exhaust.
"It helps keep the seals lubricated and stops leaks." No, it doesn't. The seals do not magically lose their ability to seal because oil isn't regularly flowing over them. In fact, the continuous change of a very cold-soaked engine to warm engine and back can actually CAUSE leaks.
"It keeps the engine parts covered in oil to prevent wear." Actually, it does the exact opposite. The absolute hardest time on an engine, the time when it wears the most, is at start-up, before the engine-driven oil pumps get a chance to start pumping oil around. This is why some expensive aircraft and racing engines have special pumps to circulate oil before the engines are started. When the bike hasn't been started for a while, the lubricating film of oil is at its very minimum - which means massive amount of wear during start up. And this is what you are doing, over and over again all winter every time you start it up - causing wear to your engine when it is at its most vulnerable.
Once we get closer to spring, I'll write a follow-up article on how to un-winterize your bike. Please feel free to comment on methods and techniques you use that work well for you!
Top
Read more: http://goldwingdocs.com/forum/viewtopic.php?t=24818#ixzz3t7fkier1
« Reply #1 on: December 01, 2015, 05:20:43 PM »
I read it also just today. I agree good article.  cooldude
My rides:
« Reply #2 on: December 01, 2015, 07:02:48 PM »
That's a long post.
What I do to winterize is this:  place the gloves and chaps in the saddle bags.  Done
sdv003
Prescott Valley, AZ
« Reply #3 on: December 01, 2015, 09:39:17 PM »
That's a long post.
+1
« Reply #4 on: December 01, 2015, 09:52:45 PM »
I was unaware that our bikes would crank if the kill switch is in the off position.
I have heard that lifting the bike clear off the ground (all winter) can be deleterious to the forks.  Maybe lifting the rear off the ground, and the front almost off but still touching is a better idea.
Bagger John - #3785
« Reply #5 on: December 02, 2015, 06:43:46 AM »
Honda's OEM owner's manuals give good advice for winter storage:
1) Wash motorcycle. Wax all painted surfaces.
2) Bring engine up to normal operating temperature by running to a nearby gas station and completely filling the tank, then ride back to your prep area.
3) Change engine oil and filter.
4) Remove plugs, squirt a teaspoon of clean motor oil into each plug hole...you can also use a fogging oil product specifically meant for winter storage. Connect plugs to their respective wires. Lay plugs on engine so their threaded ends make good electrical contact.
5) Drain carburetors. Leave bowl drain screws open.
6) Crank engine over several times until Oil Pressure light goes out.
7) Replace plugs. Tighten lightly, and replace wires. (You'll clean them and check the electrode gaps in spring when breaking the bike out of storage.)
8 ) Remove battery and store inside. Charge every month or so with a float charger.
9) Cover ALL polished or chromed surfaces (including wheels, brake rotors and fork tubes) with a moisture-displacing spray lubricant. Auto Zone used to sell one I really liked, and Advance carries a similar formulation. CRC 5-56 is good if you can find it.
10) Add 1 to 1 1/2 oz of Sta-Bil Marine (blue) Fuel Stabilizer to the tank. (Seafoam and similar products are cleaners, not stabilizers. They're good for their intended uses for but should not be used as a long-term fuel storage solution.)
11) Don't cover the pipe tips. There are weep holes at the bottom of each muffler and you'll get condensation in the pipes regardless...which will take longer to evaporate if airflow is restricted.
12) Push motorcycle into a storage area away from direct sunlight and rain, then cover with a breathable motorcycle cover - don't use a plastic tarp!
I've used this process on 30+ motorcycles over the 32 years I've been street riding...sometimes as many as 6 per layup...and have yet to encounter a rusted pipe, rusted piece of chrome, gummed-up carb or seized piston ring. Leaving the bowl drain screws open on our Valks also minimizes the possibility of a hydrolock if your petcock is flaky. The gas simply runs out the drain hoses and onto the garage floor.
« Last Edit: December 02, 2015, 06:45:38 AM by Bagger John - #3785 » Logged
nogrey
Nampa, Idaho
« Reply #6 on: December 04, 2015, 01:10:35 PM »
You can't go wrong following those simple instructions. The thing I liked about what the post said was how well he explained the "why's" behind his logic. It all made sense to me. Especially the part about not starting your bike ever so often in the winter just to run it, and how this would be worse for it. I also noted some things that may be more important in some climates than in others. In dryer climates, or for bikes that are stored in climate controlled environments, some of the covering, and extra attention to surface protection may be less necessary than in much more humid climates.
Tfrank59
'98 Tourer
Western Washington
« Reply #7 on: December 04, 2015, 04:39:25 PM »
That's a long post.
You Florida guys sheesh.  But you're right, it'd just about take all winter to read that post!  Up here in Washington state I don't winterize because I ride.  Also done. Grin
-Tom
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #8 on: December 04, 2015, 04:45:27 PM »
That's a long post.
+1
+2, Never have winterized a bike......even when I lived in PA
« Reply #9 on: December 04, 2015, 06:12:06 PM »
That's a long post.
Me 2.
Haters can hate all they want.
It's just location, location, .location.
« Reply #10 on: December 04, 2015, 06:53:02 PM »
I am fortunate enough to live in Kansas, where one can usually
 get a ride at least once a week, if you don't mind the temperature.  Keeping the garage heated helps also. I spend a lot of time in the man cave.  The old collector car and bikes reside there also.  Hoser   cooldude
h13man
Indiana NW Central Flatlands
« Reply #11 on: December 05, 2015, 06:26:56 AM »
Full tank of 91 octane with Seafoam/B12, Stabil, and a nice soft cotton sheet for the winter in my somewhat climate controlled  garage and let her sleep. I don't change oil until its due @ 5,000 mi. If oil is so corrosive to change before its due, why the heck are we using it? My van sits out year around and gets changed when needed so my bike isn't anymore special sitting in a protected inviroment. I do apply the battery tender a couple times a winter just for grins otherwise I just count the days from Dec. 23 to March 23.
« Reply #12 on: December 05, 2015, 10:43:21 AM »
It's not the oil, it's the moisture in the oil that mixes with the petrolums that form ACIDs that will eat away the metal parts (over a very long time). More moisture equals more potential acids.
2 ways to remove these unwanted items in your oil/bike. Change the oil out, or run the bike till the oil gets to running temp for a VERY long time, so those items "boil" off, leaving "clean" oil behind. This does not mean start the bike in the garage for 10 min, but get out for a 100 mile ride or something.
Which is easier? Which one do you have time for? I ride year round, so my oil gets changed in the spring, contrary to the winterizing, since it never gets put away.
h13man
« Reply #13 on: December 05, 2015, 01:39:20 PM »
Thus I don't start mine @ all until spring. The usage of salt on the roadways deters any thought of doing a winter ride.
nogrey
Nampa, Idaho
« Reply #14 on: December 05, 2015, 07:13:14 PM »
I think in the longrun, we all do what works for us. Some of us are more OCD than others, and we do what our conscience dictates. I think the other thing (for me) is just the joy of working on a truly magnificent machine. There are two basic philosphies when it come's to maintenance: 1) "If it ain't broke, don't fix it". I think for many, this is the right philosophy, especially given their lack of mechanical ability. Now please, don't take this as a knock. We all use this philosophy on things we don't fully understand and for these cases, it's probably the best policy.
2) "Mantenance is the best practice". This is the one I subscribe to. It has served me well for 57 years, it's my philosophy, it's my occupation, and it's been a lifelong practice. For me, it provides the peace of mind when I climb into the seat of what is arguably one of the more dangerous machines, of knowing that I have done everything possible to assure the safety and absolute best performance during that run.
I suppose whichever philosophy one subscribes to, it's a given that these machines will stand up to much and still keep running. That's part of the beauty of owning one. Do I do too much maintenance? Is it overkill? Probably. But no one ever complained that they did too much maintenance when their bike didn't break down. And I love knowing that it's been done better than most. That's just me.
Williamsburg, KY
« Reply #15 on: December 06, 2015, 03:47:03 AM »
Wise words  cooldude
Bagger John - #3785
« Reply #16 on: December 07, 2015, 06:46:29 AM »
Of course, none of the above applies to either of my C-14s...which are kept online year round!  Grin
What I do for a four-season bike is to change its oil and filter around the time I store the Valkyries. A thorough washing of the whole bike follows, then all exposed fasteners get a coating of the protectant oil I mentioned earlier. Tire pressure is checked and brought up to spec if low. The only chrome on either bike is on the brake and clutch lever adjuster knobs, so no worries about salt damage. Regardless, I don't ride on wet roads - and try to wash them if they pick up any salt dust when out and about.
If ridden infrequently - say, once every couple of weeks - or if very cold temps are forecast the bikes are connected to battery tenders for the duration. If a long stretch of bad weather is anticipated and they won't be ridden for an extended period of time I'll fill the tanks up, add Sta-Bil or some other stabilizer then adjust tire pressure, put bikes on their centerstands, connect tenders then cover them to keep dust off.
Living in a region which suffers from bouts of lake-effect snow makes for a hit-or-miss winter riding season. We've gotten off very lucky so far this year. It'll be warm enough to ride this week without using heated clothes!
« Last Edit: December 07, 2015, 06:49:52 AM by Bagger John - #3785 » Logged
Tfrank59
'98 Tourer
Western Washington
« Reply #17 on: December 07, 2015, 08:26:46 AM »
Well it's a balmy 50° here in the Seattle area this week, but very wet.  It's a very rare thing when we see lowland snow, so I'm glad that there isn't much of that salt crap being put down on the roads here.  I guess if there was more snow and ice, like when I lived in New England, I would have to winterize my girl.
-Tom
