February 11, 2026, 09:56:52 AM *
Author Topic: another U-joint question  (Read 1067 times)
Tfrank59
'98 Tourer
Western Washington
« on: December 02, 2015, 07:36:53 AM »
So I picked up a used one on Ebay pretty cheap, thinking it might be a good spare, but when it showed up I put it in a vise and this u-joint has maybe .020" radial play (with some pressure).  Is that not worth even installing if I end up needing to change out the u-joint I now have?  Seems like for all the hassle to change a Valk u-joint, not least getting that cursed boot back on, a person might just as well go with a brand new OEM u-joint?  thanks.
-Tom
« Reply #1 on: December 02, 2015, 07:47:19 AM »
It might go 100,000 miles.
The whole time you'll be wondering if you'll
make it to the next corner  Wink ...
« Reply #2 on: December 02, 2015, 08:29:35 AM »
Keep it in the saddle bag til you NEED it. More likely than not WILL get you home. Rear wheel bearings and U-joint R & R at 103000+ miles. While the U-joint did not fail completely it HAS seen better days. It WILL get me home if need be. When I R & Rd the U-joint I went with a new boot. RIDE SAFE.
« Reply #3 on: December 02, 2015, 09:31:28 AM »
For all the work it required replacing one for this novice, I sure wouldn't stick a used one in there (unless absolutely convinced it was as good as new).
Put it in the bags for trips.  But if you break down near home, order a new one.  With two bikes, I keep a new one (and shaft and pinion and boot) in my parts bin, with a lot of other things.
highmiles
delco north Carolina
« Reply #4 on: December 02, 2015, 12:10:28 PM »
My u-joint went out at 96k.replaced joint,dampers,and shock bushing.parts from direct line parts for$200.00 bucks.posted pictures at justpics of the u-joint.no used parts in the rear end for me.
Grandpot
Fort Mill, South Carolina
« Reply #5 on: December 03, 2015, 04:43:12 AM »
The fact that you are asking the question means you aren't comfortable with the situation.  Go with your gut feel.  Buy a new one.
Tfrank59
'98 Tourer
Western Washington
« Reply #6 on: December 03, 2015, 07:50:29 AM »
You are absolutely right.  Thing is new ones are kind of pricey, so I'm thinking I would wait and buy one when the one I have goes out Grin. My bike only has 45 K on it, and I don't think there's anything bad going on in there, but since I have a spare pumpkin, spare driveshaft, spare whole rear wheel, might as well also have a u-joint.
-Tom
Promagnaman
North Dakota
« Reply #7 on: December 03, 2015, 07:54:46 AM »
My u-joint went bad at 42,000 miles...
Tfrank59
'98 Tourer
Western Washington
« Reply #8 on: December 03, 2015, 08:59:34 AM »
That's a drag. Seems a bit premature – what kind of riding you do? Cheesy
-Tom
