February 11, 2026, 09:56:51 AM *
Author Topic: Quick question about headlight bulb access  (Read 784 times)
Fazer
« on: December 04, 2015, 06:08:28 AM »
Going to add the smartswitch from BonS on my 98 Tourer.  Is it necessary to remove the windshield to get the headlight bezel off?  I can see the screws, but it looks like there is interference fro the shield.  I'll try to get them with a long screwdriver but if any of you out there that have already done this and know the best procedure, it might save me some cursing.
Greg
Nothing in moderation...
« Reply #1 on: December 04, 2015, 06:17:09 AM »
OEM shield is just 4 bolts, but you can do it with a long Phillips.
WintrSol
Florissant, MO
« Reply #2 on: December 04, 2015, 07:10:57 AM »
You CAN get them out with a long screwdriver, but I can't get a straight shot with my windshield mounted. As noted, it's just four bolts and lift it away; IMO, well worth the frustration of stripping a screw head, if the threads have grown some rust over the years.
Fazer
« Reply #3 on: December 04, 2015, 08:28:31 AM »
Thanks guys--I'll move the widshield.
Bone
« Reply #4 on: December 04, 2015, 08:30:13 AM »
Just did my 98 Tourer with a Clearview shield but OEM brackets. The picture is from ShopTalk
remove the 4 #15 bolts to remove. I just loosened the bottom #15 on each side and had enough
room for a long screwdriver.
http://www.valkyrieriders.com/shoptalk/GL1/gl64_small.jpg
