February 11, 2026, 09:56:25 AM *
Author Topic: Question about torque wrench  (Read 1211 times)
shortleg
maryland
« on: December 08, 2015, 04:04:10 AM »
   If I have to add a 1/2 inch to 3/8 adapter to my wrench
because I do not have a 1/2 inch drive socket that size.
  What affect dose it have on the torque reading ?
           shortleg
Paladin528
« Reply #1 on: December 08, 2015, 04:47:48 AM »
wrench setting = desired torque x wrench length / (wrench length + extension length)
so if you were 80 pound feet specified with a 3 inch extension (24 inch wrench) then it would be
Ts=80*24 / 24+3
Ts=1920 / 27
Ts=71.1lb/Ft
I should add that this only applies when the extension is in line with the wrench.  the formula changes when the extension is at an angle.
Here is a good guide for how to calculate.
http://www.trialsnuts.com/torqued.pdf
« Last Edit: December 08, 2015, 04:52:48 AM by Paladin528 » Logged
Roidfingers
Tuscaloosa, Alabama
« Reply #2 on: December 08, 2015, 04:58:46 AM »
Why would an extension from the wrench to the socket have any effect at all on torque ?
 I could understand if you were adding an extension out beyond the torque sprocket forward in a lineal way.
« Last Edit: December 08, 2015, 05:07:27 AM by Roidfingers » Logged
Paladin528
« Reply #3 on: December 08, 2015, 05:01:25 AM »
I red the post wrong.  I was thinking of an extension to the LENGTH of the wrench.  Just stepping it down has ZERO effect on the applied torque.
« Reply #4 on: December 08, 2015, 07:14:25 AM »
           shortleg
None.
shortleg
maryland
« Reply #5 on: December 08, 2015, 03:28:04 PM »
  Thank you guys
     shortleg[Dave]
« Reply #6 on: December 08, 2015, 03:43:20 PM »
Whew ! I thought I was going to have to do some algebra .  Smiley
westnek
« Reply #7 on: December 08, 2015, 04:23:05 PM »
al who????  maybe I missing  something I just go realy  tight,, tight, and a bit tight,  , snug ==that's very interesting post  merry Christmas to all  west
gregk
Retired
Chippewa Falls, wi.
« Reply #8 on: December 08, 2015, 08:36:19 PM »
Yup, as said it does not change nor would an extension  90deg. to the handle change the value.  Only if you are extending the length of the beem like using a crowfoot wrench for example. Try not to use a universal joint.   I think you might be able to bring up a formula at snapon tools or ask your smart phone for a formula to calculate torque when extending the length of the handle.
« Reply #9 on: December 09, 2015, 07:51:14 AM »
It would seem to me that if you have to reduce the drive size to accommodate a socket, that you are using the wrong tool
and are increasing the chance of twisting off the fastener or stripping out the threads. large torque wrenches on small
size bolts/nuts is the prescription for failure. Torque wrenches are probably responsible for the majority of fastener
problems such as ripped out threads and twisted off bolts and nuts.
WintrSol
Florissant, MO
« Reply #10 on: December 09, 2015, 09:12:28 AM »
I agree - a 1/2" torque wrench is often rated up to about 150lb-ft (sometimes more), and rated accuracy is given in a % of full scale. A really expensive one may be rated +/-1% or less, but that's still +/-1.5lb-ft, so when set to 20, you could actually be at 18.5 or 21.5, which could be enough for stretching a fastener or pulling threads out of aluminum. You should always use a torque wrench closer to it's limit, not near the bottom of the range, IMO.
« Reply #11 on: December 09, 2015, 10:42:06 AM »
Now maybe, just maybe, Shortleg just happens to have only a 1/2" t-wrench and needs to use, lets say, a 3/4" socket.  But, lets say his 3/4" 1/2" drive socket is missing/broken and his only option is to use his 1/2 to 3/8 adapter and his 3/8" drive 3/4" socket.
It appears to me that that would be a similar scenario to his original post and a possibility for his question.
He may have some idea as to what tonnage he wants to set the fastener to/at, and, knows to sneak up on that setting.
Just saying.
